Ana içeriğe geç
iPod 2nd Generation Display Replacement
Neye ihtiyacın var
  1. iPod 2nd Generation Display Replacement, Rear Panel: adım 1, 1 resimden 1.
    • Before opening your iPod, ensure that the hold switch is in the locked position.
    FixBot'a Sor
    Yorum Ekle
  2. iPod 2nd Generation Display Replacement: adım 2, 1 resimden 1.
    • Opening the iPod can be challenging. Don't get discouraged if it takes a few tries before the iPod is opened.
    • Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
    FixBot'a Sor
    Yorum Ekle
  3. iPod 2nd Generation Display Replacement: adım 3, 1 resimden 1.
    • Continue to run the opening tool along the side of the case until all five tabs have been released.
    FixBot'a Sor
    Yorum Ekle
  4. iPod 2nd Generation Display Replacement: adım 4, 1 resimden 1.
    • Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
    FixBot'a Sor
    Yorum Ekle
  5. iPod 2nd Generation Display Replacement: adım 5, 1 resimden 1.
    • Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
    FixBot'a Sor
    Yorum Ekle
  6. iPod 2nd Generation Display Replacement: adım 6, 1 resimden 1.
    • Lift the rear panel away from the iPod, making sure it doesn't catch on the headphone jack.
    FixBot'a Sor
    Yorum Ekle
  7. iPod 2nd Generation Display Replacement, Hard Drive: adım 7, 1 resimden 1.
    • Peel up the metallic tape attached to the top of the battery.
    FixBot'a Sor
    Yorum Ekle
  8. iPod 2nd Generation Display Replacement: adım 8, 1 resimden 1.
    • Lift the battery up from the hard drive and lay it next the the iPod (it is still connected to the logic board).
    FixBot'a Sor
    Yorum Ekle
  9. iPod 2nd Generation Display Replacement: adım 9, 1 resimden 1.
    • Carefully disconnect the orange ribbon cable from the hard drive.
    • If the cable doesn't come free easily, it may be helpful to gently wiggle the cable from side to side.
    • Lift the hard drive out of the iPod.
    FixBot'a Sor
    Yorum Ekle
  10. iPod 2nd Generation Display Replacement, Hard Drive Cable: adım 10, 1 resimden 1.
    • For the following step, you only need to move the locking bar about 2 mm. Pushing too hard or too far will damage the connector.
    • Loosen the connector by pulling the brown locking bar toward the hard drive cable using the tips of your fingers.
    FixBot'a Sor
    Yorum Ekle
  11. iPod 2nd Generation Display Replacement: adım 11, 1 resimden 1.
    • Slide the hard drive cable out of its connector.
    FixBot'a Sor
    Yorum Ekle
  12. iPod 2nd Generation Display Replacement, Display: adım 12, 1 resimden 1.
    • Lift the blue hard drive mounting bracket out of the iPod.
    FixBot'a Sor
    Yorum Ekle
  13. iPod 2nd Generation Display Replacement: adım 13, 1 resimden 1.
    • Carefully disconnect the white battery connector from the logic board. Be sure to pull only on the connector itself and not on the cables.
    FixBot'a Sor
    Yorum Ekle
  14. iPod 2nd Generation Display Replacement: adım 14, 1 resimden 1.
    • Like the hard drive connector, for the following step, you only need to move the connector about 2 mm. Pushing too hard or too far will damage the connector.
    • Loosen the touch wheel connector by pulling the brown locking bar toward the side of the iPod using the tips of your fingers.
    FixBot'a Sor
    Yorum Ekle
  15. iPod 2nd Generation Display Replacement: adım 15, 1 resimden 1.
    • Remove the 8 T6 Torx screws from the logic board.
    FixBot'a Sor
    Yorum Ekle
  16. iPod 2nd Generation Display Replacement: adım 16, 1 resimden 1.
    • Lift the logic board up enough to disconnect the orange touch wheel cable.
    • Lift the logic board out of the iPod.
    FixBot'a Sor
    Yorum Ekle
  17. iPod 2nd Generation Display Replacement: adım 17, 1 resimden 1.
    • Note the location of the four white plastic tabs securing the display to the logic board. These tabs must be released before the display can be removed.
    FixBot'a Sor
    Yorum Ekle
  18. iPod 2nd Generation Display Replacement: adım 18, 1 resimden 1.
    • Use a spudger or your finger to free the four white plastic tabs indicated in the previous picture.
    FixBot'a Sor
    Yorum Ekle
  19. iPod 2nd Generation Display Replacement: adım 19, 1 resimden 1.
    • Use a spudger to carefully disconnect the display ribbon cable from beneath the scroll wheel.
    • Lift the display off the logic board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
iRobot
1 İtibar
636 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 53
Her zaman: 8,357
