Ana içeriğe geç
iPod 2nd Generation Logic Board Replacement
Neye ihtiyacın var
  1. iPod 2nd Generation Logic Board Replacement, Rear Panel: adım 1, 1 resimden 1.
    • Before opening your iPod, ensure that the hold switch is in the locked position.
    FixBot'a Sor
    Yorum Ekle
  2. iPod 2nd Generation Logic Board Replacement: adım 2, 1 resimden 1.
    • Opening the iPod can be challenging. Don't get discouraged if it takes a few tries before the iPod is opened.
    • Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
    FixBot'a Sor
    Yorum Ekle
  3. iPod 2nd Generation Logic Board Replacement: adım 3, 1 resimden 1.
    • Continue to run the opening tool along the side of the case until all five tabs have been released.
    FixBot'a Sor
    Yorum Ekle
  4. iPod 2nd Generation Logic Board Replacement: adım 4, 1 resimden 1.
    • Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
    FixBot'a Sor
    Yorum Ekle
  5. iPod 2nd Generation Logic Board Replacement: adım 5, 1 resimden 1.
    • Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
    FixBot'a Sor
    Yorum Ekle
  6. iPod 2nd Generation Logic Board Replacement: adım 6, 1 resimden 1.
    • Lift the rear panel away from the iPod, making sure it doesn't catch on the headphone jack.
    FixBot'a Sor
    Yorum Ekle
  7. iPod 2nd Generation Logic Board Replacement, Hard Drive: adım 7, 1 resimden 1.
    • Peel up the metallic tape attached to the top of the battery.
    FixBot'a Sor
    Yorum Ekle
  8. iPod 2nd Generation Logic Board Replacement: adım 8, 1 resimden 1.
    • Lift the battery up from the hard drive and lay it next the the iPod (it is still connected to the logic board).
    FixBot'a Sor
    Yorum Ekle
  9. iPod 2nd Generation Logic Board Replacement: adım 9, 1 resimden 1.
    • Carefully disconnect the orange ribbon cable from the hard drive.
    • If the cable doesn't come free easily, it may be helpful to gently wiggle the cable from side to side.
    • Lift the hard drive out of the iPod.
    FixBot'a Sor
    Yorum Ekle
  10. iPod 2nd Generation Logic Board Replacement, Hard Drive Cable: adım 10, 1 resimden 1.
    • For the following step, you only need to move the locking bar about 2 mm. Pushing too hard or too far will damage the connector.
    • Loosen the connector by pulling the brown locking bar toward the hard drive cable using the tips of your fingers.
    FixBot'a Sor
    Yorum Ekle
  11. iPod 2nd Generation Logic Board Replacement: adım 11, 1 resimden 1.
    • Slide the hard drive cable out of its connector.
    FixBot'a Sor
    Yorum Ekle
  12. iPod 2nd Generation Logic Board Replacement, Display: adım 12, 1 resimden 1.
    • Lift the blue hard drive mounting bracket out of the iPod.
    FixBot'a Sor
    Yorum Ekle
  13. iPod 2nd Generation Logic Board Replacement: adım 13, 1 resimden 1.
    • Carefully disconnect the white battery connector from the logic board. Be sure to pull only on the connector itself and not on the cables.
    FixBot'a Sor
    Yorum Ekle
  14. iPod 2nd Generation Logic Board Replacement: adım 14, 1 resimden 1.
    • Like the hard drive connector, for the following step, you only need to move the connector about 2 mm. Pushing too hard or too far will damage the connector.
    • Loosen the touch wheel connector by pulling the brown locking bar toward the side of the iPod using the tips of your fingers.
    FixBot'a Sor
    Yorum Ekle
  15. iPod 2nd Generation Logic Board Replacement: adım 15, 1 resimden 1.
    • Remove the 8 T6 Torx screws from the logic board.
    FixBot'a Sor
    Yorum Ekle
  16. iPod 2nd Generation Logic Board Replacement: adım 16, 1 resimden 1.
    • Lift the logic board up enough to disconnect the orange touch wheel cable.
    • Lift the logic board out of the iPod.
    FixBot'a Sor
    Yorum Ekle
  17. iPod 2nd Generation Logic Board Replacement: adım 17, 1 resimden 1.
    • Note the location of the four white plastic tabs securing the display to the logic board. These tabs must be released before the display can be removed.
    FixBot'a Sor
    Yorum Ekle
  18. iPod 2nd Generation Logic Board Replacement: adım 18, 1 resimden 1.
    • Use a spudger or your finger to free the four white plastic tabs indicated in the previous picture.
    FixBot'a Sor
    Yorum Ekle
  19. iPod 2nd Generation Logic Board Replacement: adım 19, 1 resimden 1.
    • Use a spudger to carefully disconnect the display ribbon cable from beneath the scroll wheel.
    • Lift the display off the logic board.
    FixBot'a Sor
    Yorum Ekle
  20. iPod 2nd Generation Logic Board Replacement, Logic Board: adım 20, 1 resimden 1.
    • Logic board remains.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
636 adet Kılavuz yazıldı
5Kılavuz Yorumları
I wish all iPods were this easy to fix!
Donald Fournier - Yanıt Paylaş
I just replaced a battery and Logic Board in an iPod 2nd Generation. Totally easy; No soldering necessary. The hardest part was waiting for the Logic Board in the mail.
My 2G will not connect to either windows or macos via FW. I have cleaned the connector, checked the logic board for obvious damage, etc. My 1G connects to the same computers just fine. The 2G otherwise works, passes all diagnostics (seems to), and wakes up and charges when I plug it in to the computer. Do I need a new logic board? Otherwise, I am thinking of just manually transferring my music to the drive and living with it.
Rusty Lingenfelter - Yanıt Paylaş
Hi,
try to replace the hard drive from your 1G first ans see if this works.
Please let me know.
Thanks,
Georg Balzereit - Yanıt Paylaş
I think there's an issue with the board at this point as I have the same exact issue. It's either one of the chips near the port or something bigger going on with one of the main chips which refuses to allow the iPod to communicate with whichever system you plug it into. I've tried modern and old systems and had zero luck. I could have the drive read if i used my iPod 3G to host the drive - beyond that, it works fine but just will not sync.
Ben Glasgow - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 42
Her zaman: 10,928
