Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Before opening your iPod, ensure that the hold switch is in the locked position. The orange bar should be visible, indicating hold is active.
Insert an opening pick as far as possible into the seam between the plastic front and the metal rear panel, on the right edge of the iPod.
Use the opening pick to pry up against the plastic front panel and release five retaining tabs (seen in the third photo).
Slide the pick along the edge of the iPod and continue prying to release the rest of the retaining tabs.
After all five tabs along the right side are free, the case should open easily.
Open the case like a book with the dock connector at the top, and lay the rear panel next to the front half of the iPod.
Use a plastic tool or your fingernails to carefully disconnect the orange headphone jack cable. Be sure to pull straight up on the connector, not the cable itself.
Lift up the hard drive with one hand and carefully disconnect the hard drive ribbon from the logic board.
Lift the hard drive out of the iPod.
Peel back the metallic tape connecting the hard drive ribbon to the blue mounting bracket.
Use a spudger to carefully disconnect the orange ribbon cable from the hard drive.
Lift the hard drive mounting bracket and cable off the hard drive.
Lift the blue and white mounting bracket off the other side of the hard drive.
34 farklı kişi bu kılavuzu tamamladı.
