Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Replace a cracked or faulty display.
Neye ihtiyacın var
Insert an opening pick as far as possible into the seam between the plastic front and the metal rear panel, on the right edge of the iPod.
Use the opening pick to pry up against the plastic front panel and release five retaining tabs (seen in the third photo).
Slide the pick along the edge of the iPod and continue prying to release the rest of the retaining tabs.
After all five tabs along the right side are free, the case should easily open.
Grasp the hard drive with one hand and carefully disconnect the orange ribbon cable from the hard drive using your other hand.
Peel up the black adhesive strip covering the hard drive ribbon cable.
Carefully disconnect the white battery connector from the logic board. Be sure to pull only on the connector itself and not on the cables.
Slide the orange click wheel ribbon cable out of its connector. You must unlock this connector before sliding the ribbon cable out. The locking mechanism is on the opposite side of where the cable is inserted - it swivels upwards 90 degrees. Use a plastic spudger to lift the locking mechanism.
Lift the display panel out of the iPod. There may be some mild adhesive connecting the display to the front panel.
48 farklı kişi bu kılavuzu tamamladı.
