Ana içeriğe geç
  1. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Before opening your iPod, ensure that the hold switch is in the locked position.  The orange bar should be visible, indicating hold is active.
    • Before opening your iPod, ensure that the hold switch is in the locked position. The orange bar should be visible, indicating hold is active.
  2. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Insert an opening pick as far as possible into the seam between the plastic front and the metal rear panel, on the right edge of the iPod. You may need to rock the pick back and forth to slide it in farther. Use the opening pick to pry up against the plastic front panel and release five retaining tabs (seen in the third photo).
    • Insert an opening pick as far as possible into the seam between the plastic front and the metal rear panel, on the right edge of the iPod.
    • You may need to rock the pick back and forth to slide it in farther.
    • Use the opening pick to pry up against the plastic front panel and release five retaining tabs (seen in the third photo).
    • Slide the pick along the edge of the iPod and continue prying to release the rest of the retaining tabs.
    • After all five tabs along the right side are free, the case should easily open.
  3. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    The iPod case is now open, but don't separate the two halves just yet. There is still an orange ribbon cable connecting the headphone jack to the logic board.
    • The iPod case is now open, but don't separate the two halves just yet. There is still an orange ribbon cable connecting the headphone jack to the logic board.
    • Open the case like a book with the dock connector edge at the top, and lay the rear panel next to the front half of the iPod.
  4. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Use a plastic tool or your fingernails to carefully disconnect the orange headphone jack cable. Be sure to pull  straight up on the connector, not the cable itself.
    • Use a plastic tool or your fingernails to carefully disconnect the orange headphone jack cable. Be sure to pull straight up on the connector, not the cable itself.
    • This ribbon cable is very fragile. If you are replacing the battery, you can choose to skip this step and keep the headphone jack connected to the motherboard. Prop and tape the rear case against a box to keep it in place. Be very careful not to strain the fragile headphone jack cable as you work.
  5. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Remove the 2 silver T6 Torx screws from the headphone jack.
    • Remove the 2 silver T6 Torx screws from the headphone jack.
  6. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Grasp the headphone jack board and lift it out of the iPod.
    • Grasp the headphone jack board and lift it out of the iPod.
  7. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Turn the headphone jack board over.
    • Turn the headphone jack board over.
    • Use the tip of your finger or a spudger to carefully flip up the black connector holding the headphone jack cable connector in place.
  8. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Pull the orange headphone jack cable directly out of its connector.
    • Pull the orange headphone jack cable directly out of its connector.
Bitiş Çizgisi
19 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
647 adet Kılavuz yazıldı
4 Yorum
How do you add a "confirmed success"? This worked perfectly for me. Thanks iRobot!
I agree that these pry tools pretty low quality. They did work faster than the guitar picks I've used in the past, but the material is just not durable. They were pretty much destroyed after one case opening.
anja - Yanıt
The instructions are great, however when you ask about spares required there is no mention of the ribbon cable I require, just the board assembly!
Chris Stockley - Yanıt
Hi
Where can I buy these components?
Thanks
Pablo Carter - Yanıt
Do you repair iPod 4th type? How much do you charge? Thanks
wcname - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 43
Her zaman: 23,249
