Ana içeriğe geç
iPod Classic Front Panel Replacement
Neye ihtiyacın var
  1. iPod Classic Front Panel Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Apple designed their new iPods to be very difficult to take apart without destroying major components. Because of the metal faceplate, the metal backing, and the 13 (yes, 13) metal clips holding the case together, this is one of the toughest iPods to disassemble.
    • Proceed with caution and the warning that you may significantly damage your iPod beyond its present condition. Also, you may want a few extra pairs of plastic opening tools during installation, as they are easy to ruin when opening the iPod. Have fun!
    • Before opening your iPod, ensure that the hold switch is in the locked position.
    FixBot'a Sor
    Yorum Ekle
  2. iPod Classic Front Panel Replacement: adım 2, 1 resimden 1.
    • Opening this iPod is challenging. Don't get discouraged if it takes you a few tries before the iPod is opened. One thing to notice is the angle of the plastic opening tool's tip while inserting it into the iPod. Ideally, the angle should be as vertical as possible while still clearing the edge of the rear panel.
    • Insert a plastic opening tool into the seam between the front and back of the iPod.
    FixBot'a Sor
    Yorum Ekle
  3. iPod Classic Front Panel Replacement: adım 3, 1 resimden 1.
    • Insert another plastic opening tool into the seam between the front and back of the iPod, leaving at least 1.5 inches of space between the two tools.
    FixBot'a Sor
    Yorum Ekle
  4. iPod Classic Front Panel Replacement: adım 4, 1 resimden 1.
    • At an angle, carefully insert a putty knife about 1/8 inch into the seam between the two opening tools.
    • There are thin metal rails running along the inside of the rear panel, so take great care when inserting the putty knife.
    • Once the putty knife has cleared the lip of the rear panel, pivot the putty knife so that it is vertical, and carefully (but firmly) wiggle it straight down into the gap between the opening tools.
    FixBot'a Sor
    Yorum Ekle
  5. iPod Classic Front Panel Replacement: adım 5, 1 resimden 1.
    • Push with your fingers on the rear panel behind the putty knife to minimize bending. Slowly flex the putty knife, as shown in the picture, to ensure that most of the metal tabs on this side of the iPod are disengaged.
    • The theory behind this method is, rather than attempting to not bend the rear panel at all, to bend it in a favorable manner that allows you to easily restore it later. Therefore, any bend in the sides of the rear panel should be drawing the lip of the rear panel away from the iPod, rather than pushing out on the curved surface. This method also disengages as many of the side clips as possible.
    FixBot'a Sor
    Yorum Ekle
  6. iPod Classic Front Panel Replacement: adım 6, 1 resimden 1.
    • Remove the putty knife from the iPod and reinsert it closer to the corner of the iPod, using the same wiggle method as before.
    • If at all possible, do not bend the corner of the rear panel.
    FixBot'a Sor
    Yorum Ekle
  7. iPod Classic Front Panel Replacement: adım 7, 1 resimden 1.
    • Near the headphone jack, insert a plastic opening tool into the seam between the front and back of the iPod.
    • You may find it easier to carefully flex the putty knife downward in order to create more of a gap for the opening tool, but be sure not to bend the corner of the rear panel!
    FixBot'a Sor
    Yorum Ekle
  8. iPod Classic Front Panel Replacement: adım 8, 1 resimden 1.
    • Near the center of the display, carefully insert a metal spudger into the gap created by the plastic opening tool.
    • It is easy to create a noticeable bump in the rear panel here that is difficult to repair. When prying the tab free, try to have the metal spudger pivot on the edge of the rear panel rather than bending the rear panel outward.
    • Using the metal spudger, disengage the single clip on the top of the iPod.
    FixBot'a Sor
    Yorum Ekle
  9. iPod Classic Front Panel Replacement: adım 9, 1 resimden 1.
    • Near the other top corner, insert a plastic opening tool into the seam between the front and back of the iPod
    FixBot'a Sor
    Yorum Ekle
  10. iPod Classic Front Panel Replacement: adım 10, 1 resimden 1.
    • On the other side, insert a plastic opening tool into the seam between the front and back of the iPod.
    • You may find it easier to angle the opening tool stuck in the top corner in order to create a sufficient gap.
    FixBot'a Sor
    Yorum Ekle
  11. iPod Classic Front Panel Replacement: adım 11, 1 resimden 1.
    • Remove the opening tool from the top corner and insert it into the seam between the front and back of the iPod, leaving at least 1.5 inches of space between the two tools (as done on the other side).
    FixBot'a Sor
    Yorum Ekle
  12. iPod Classic Front Panel Replacement: adım 12, 1 resimden 1.
    • Again, there are thin metal rails running along the inside of the rear panel, so take great care when inserting the putty knife.
    • Once the putty knife has cleared the lip of the rear panel, angle the putty knife so that it is vertical, and carefully (but firmly) wiggle it straight down into the iPod via the gap between the plastic opening tools.
    • Push with your fingers on the rear panel behind the putty knife to minimize bending. Ever so slightly flex the putty knife to ensure that most of the metal tabs on this side of the iPod are disengaged.
    FixBot'a Sor
    Yorum Ekle
  13. iPod Classic Front Panel Replacement: adım 13, 1 resimden 1.
    • The metal clips near the corners are notorious for tenaciously gripping the front panel. It is necessary to disengage these clips in order to open the iPod.
    • Carefully insert a metal spudger into the area near the stubborn metal clip.
    FixBot'a Sor
    Yorum Ekle
  14. iPod Classic Front Panel Replacement: adım 14, 1 resimden 1.
    • Gently wiggle the metal spudger down so that it is all the way in the rear panel.
    FixBot'a Sor
    Yorum Ekle
  15. iPod Classic Front Panel Replacement: adım 15, 1 resimden 1.
    • Gently begin to disengage the clip from the front panel.
    FixBot'a Sor
    Yorum Ekle
  16. iPod Classic Front Panel Replacement: adım 16, 1 resimden 1.
    • Continue to push up on the front panel with the metal spudger until the metal clip releases.
    FixBot'a Sor
    Yorum Ekle
  17. iPod Classic Front Panel Replacement: adım 17, 1 resimden 1.
    • There are two ribbon cables connecting the rear panel to the rest of the iPod. In the following step, be careful not to damage these ribbon cables.
    • Grasp the front panel assembly with one hand and the rear panel with the other.
    • Take a deep breath!
    • Gently (GENTLY) disengage the remaining clips on the rear panel by pulling the tops of the front and rear panels away from each other (think of the bottom of the iPod as a hinge), taking great care not to damage the ribbon cables holding the two halves together.
    FixBot'a Sor
    Yorum Ekle
  18. iPod Classic Front Panel Replacement: adım 18, 1 resimden 1.
    • Use a spudger to slide up the connector holding the orange battery ribbon in place. You only need to lift the locking bar up about 2 mm to free the cable.
    • Slide the orange battery ribbon out of its connector.
    FixBot'a Sor
    Yorum Ekle
  19. iPod Classic Front Panel Replacement: adım 19, 1 resimden 1.
    • Place the rear panel next to the iPod, being careful not to strain the orange headphone jack cable.
    FixBot'a Sor
    Yorum Ekle
  20. iPod Classic Front Panel Replacement: adım 20, 1 resimden 1.
    • Lift the hard drive up with one hand so you can access the headphone jack ribbon beneath.
    • Use a spudger to flip up the plastic tab holding the headphone jack ribbon in place. The tab will rotate up 90 degrees, releasing the ribbon cable.
    • Slide the orange headphone jack ribbon out of its connector.
    • The rear panel is now free from the iPod.
    FixBot'a Sor
    Yorum Ekle
  21. iPod Classic Front Panel Replacement: adım 21, 1 resimden 1.
    • Now to repair the damage caused by liberating the internal parts of the iPod Classic! It is highly likely that at least one of the metal clips in the lower case has been bent upward. These clips must all be pointing downward in order to reinstall the rear panel.
    FixBot'a Sor
    Yorum Ekle
  22. iPod Classic Front Panel Replacement: adım 22, 1 resimden 1.
    • Take the broad, flat side of the metal spudger and push the clip down, taking care not to tear the thin metal rail from the rear panel.
    • Be careful not to damage any of the headphone jack parts while shaping these clips!
    FixBot'a Sor
    Yorum Ekle
  23. iPod Classic Front Panel Replacement: adım 23, 1 resimden 1.
    • On a clean, hard surface, lay the rear panel on its side. Carefully but firmly push down on it, rolling the entire lip side back into its proper spot.
    • It may be necessary to do this multiple times in order to achieve optimal straightness on the sides. It is better to have the edges of the case pushed in slightly too far rather than not far enough, because the reseating of the front panel will bend the rear panel into its correct alignment.
    • Now that the rear panel is back to a beautiful condition, you can move on to repairing the iPod!
    FixBot'a Sor
    Yorum Ekle
  24. iPod Classic Front Panel Replacement: adım 24, 1 resimden 1.
    • Rotate the hard drive out of the framework and place it so that the connector is facing up.
    • Use a spudger to flip up the small black locking tab holding the orange hard drive ribbon in place. The tab will rotate up 90 degrees, releasing the ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  25. iPod Classic Front Panel Replacement: adım 25, 1 resimden 1.
    • Slide the orange hard drive ribbon cable directly out of its connector.
    • If you are replacing the hard drive in your iPod and it did not come with the rubber mounting brackets and foam padding, transfer these items from your old drive to the replacement drive.
    FixBot'a Sor
    Yorum Ekle
  26. iPod Classic Front Panel Replacement, Front Panel: adım 26, 1 resimden 1.
    • Remove the three Phillips screws securing the front panel to the metal framework.
    FixBot'a Sor
    Yorum Ekle
  27. iPod Classic Front Panel Replacement: adım 27, 1 resimden 1.
    • Rotate the iPod 180 degrees and remove the three Phillips screws securing the front panel to the metal framework on the other side.
    FixBot'a Sor
    Yorum Ekle
  28. iPod Classic Front Panel Replacement: adım 28, 1 resimden 1.
    • Carefully work around the edges of the iPod to separate the front panel from the gray metal framework.
    • You may meet some resistance, as there is a mild adhesive used to help hold the two pieces together.
    FixBot'a Sor
    Yorum Ekle
  29. iPod Classic Front Panel Replacement: adım 29, 1 resimden 1.
    • Lift the framework (including the attached screen, logic board, and click wheel) away from the front panel.
    • Make sure that the click wheel button is in place before reinstalling the framework in the front panel.
    FixBot'a Sor
    Yorum Ekle
  30. iPod Classic Front Panel Replacement: adım 30, 1 resimden 1.
    • The front panel is now free from the iPod.
    FixBot'a Sor
    Yorum Ekle
Sonuç
48 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
636 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 22
Son 7 gün: 106
Son 30 gün: 437
Her zaman: 80,933
