Giriş
The colored metal casing.
Parçalar
Hiçbir parça belirtilmedi.
Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic top. Use the screwdriver to pry up the white plastic top bezel. Be careful not to damage the soft plastic with your screwdriver.
To make this job easier, heat up the adhesive with a hairdryer on low heat for a few seconds.
Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic bottom Use the screwdriver to pry up the white plastic bottom bezel. Be careful not to damage the soft plastic with your screwdriver.
A small pair of snap ring pliers is the easiest tool to remove the metal retaining bracket.
You can also use a flathead screwdriver to pry out the metal retaining bracket beneath the bottom bezel as shown. You can free the bracket by first pushing in the metal arms on the corners and then lifting the bracket.
Use a spudger or the tip of your finger to carefully disconect the orange click wheel ribbon from the logic board.
20 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Followed your instructions to the letter. Put it back together and now it won't work . Thanks for breaking my iPod mini.
You probably &&^&@@ something up by mistake. Don’t blame the author for your own mistakes.
