Ana içeriğe geç
iPod Mini Casing Replacement
Neye ihtiyacın var
  1. iPod Mini Casing Replacement, Top Bezel: adım 1, 1 resimden 1.
    • Before opening your iPod, ensure that the hold switch is in the locked position.
    FixBot'a Sor
    Yorum Ekle
  2. iPod Mini Casing Replacement: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    Jimmy
    $7.95
    • Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic top. Use the screwdriver to pry up the white plastic top bezel. Be careful not to damage the soft plastic with your screwdriver.
    • The top bezel is held on with an adhesive, so it may be necessary to pry up in several different locations to free the part.
    • To make this job easier, heat up the adhesive with a hairdryer on low heat for a few seconds.
    FixBot'a Sor
    Yorum Ekle
  3. iPod Mini Casing Replacement: adım 3, 1 resimden 1.
    • Lift the top bezel off of the iPod.
    FixBot'a Sor
    Yorum Ekle
  4. iPod Mini Casing Replacement, Bottom Bezel: adım 4, 1 resimden 1.
    Jimmy
    $7.95
    • Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic bottom Use the screwdriver to pry up the white plastic bottom bezel. Be careful not to damage the soft plastic with your screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. iPod Mini Casing Replacement: adım 5, 1 resimden 1.
    • A small pair of snap ring pliers is the easiest tool to remove the metal retaining bracket.
    • You can also use a flathead screwdriver to pry out the metal retaining bracket beneath the bottom bezel as shown. You can free the bracket by first pushing in the metal arms on the corners and then lifting the bracket.
    FixBot'a Sor
    Yorum Ekle
  6. iPod Mini Casing Replacement: adım 6, 1 resimden 1.
    • Lift the metal retaining bracket out of the iPod.
    FixBot'a Sor
    Yorum Ekle
  7. iPod Mini Casing Replacement, Casing: adım 7, 1 resimden 1.
    • Use a spudger or the tip of your finger to carefully disconect the orange click wheel ribbon from the logic board.
    FixBot'a Sor
    Yorum Ekle
  8. iPod Mini Casing Replacement: adım 8, 1 resimden 1.
    • Remove the two #00 Phillips screws securing the headphone jack to the casing.
    FixBot'a Sor
    Yorum Ekle
  9. iPod Mini Casing Replacement: adım 9, 1 resimden 1.
    • Carefully slide the iPod out of its casing by pushing on the logic board near the bottom edge of the click wheel.
    • Do not pull on the headphone jack board at the top of the iPod, as the connector to the logic board is fragile.
    FixBot'a Sor
    Yorum Ekle
  10. iPod Mini Casing Replacement: adım 10, 1 resimden 1.
    • After pushing the logic board out sufficiently, gently grasp the logic board on either side of the display, and continue to slide the iPod out of its casing.
    FixBot'a Sor
    Yorum Ekle
  11. iPod Mini Casing Replacement: adım 11, 1 resimden 1.
    • Use a spudger to pull back on the small black plastic tab holding the click wheel in place.
    FixBot'a Sor
    Yorum Ekle
  12. iPod Mini Casing Replacement: adım 12, 1 resimden 1.
    • Continue to pull back on the black plastic tab and use your other hand to press down on the click wheel and begin to slide it out of the iPod.
    • It's important to press down on the click wheel as you slide it out, otherwise the click wheel could be scratched by the iPod's metal casing.
    FixBot'a Sor
    Yorum Ekle
  13. iPod Mini Casing Replacement: adım 13, 1 resimden 1.
    • Continue to slide the click wheel out until it is free of the iPod.
    FixBot'a Sor
    Yorum Ekle
  14. iPod Mini Casing Replacement: adım 14, 1 resimden 1.
    • Exterior casing remains.
    FixBot'a Sor
    Yorum Ekle
Sonuç
24 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
636 adet Kılavuz yazıldı
4Kılavuz Yorumları
Followed your instructions to the letter. Put it back together and now it won't work . Thanks for breaking my iPod mini.
kolbyhardy - Yanıt Paylaş
You probably &&^&@@ something up by mistake. Don’t blame the author for your own mistakes.
Crystal Haugh - Yanıt Paylaş
dude the pod mini is an mp3 player from 2005 it literally does not matter, plus, you probably &&^&@@ up the repair anyways
Memez_idk - Yanıt Paylaş
@kolbyhardy He didn't touch your ipod mini. Anything you did to it is YOUR fault, not anyone else's, own your mistakes.
Cactus12 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 42
Son 30 gün: 186
Her zaman: 30,748
