Ana içeriğe geç
iPod Mini Logic Board Replacement
Neye ihtiyacın var
  1. iPod Mini Logic Board Replacement, Top Bezel: adım 1, 1 resimden 1.
    • Before opening your iPod, ensure that the hold switch is in the locked position.
    FixBot'a Sor
    Yorum Ekle
  2. iPod Mini Logic Board Replacement: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    Jimmy
    $7.95
    • Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic top. Use the screwdriver to pry up the white plastic top bezel. Be careful not to damage the soft plastic with your screwdriver.
    • The top bezel is held on with an adhesive, so it may be necessary to pry up in several different locations to free the part.
    • To make this job easier, heat up the adhesive with a hairdryer on low heat for a few seconds.
    FixBot'a Sor
    Yorum Ekle
  3. iPod Mini Logic Board Replacement: adım 3, 1 resimden 1.
    • Lift the top bezel off of the iPod.
    FixBot'a Sor
    Yorum Ekle
  4. iPod Mini Logic Board Replacement, Bottom Bezel: adım 4, 1 resimden 1.
    Jimmy
    $7.95
    • Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic bottom Use the screwdriver to pry up the white plastic bottom bezel. Be careful not to damage the soft plastic with your screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. iPod Mini Logic Board Replacement: adım 5, 1 resimden 1.
    • A small pair of snap ring pliers is the easiest tool to remove the metal retaining bracket.
    • You can also use a flathead screwdriver to pry out the metal retaining bracket beneath the bottom bezel as shown. You can free the bracket by first pushing in the metal arms on the corners and then lifting the bracket.
    FixBot'a Sor
    Yorum Ekle
  6. iPod Mini Logic Board Replacement: adım 6, 1 resimden 1.
    • Lift the metal retaining bracket out of the iPod.
    FixBot'a Sor
    Yorum Ekle
  7. iPod Mini Logic Board Replacement, Display: adım 7, 1 resimden 1.
    • Be careful, this connector is fragile.
    • Use a spudger or the tip of your finger to carefully disconect the orange click wheel ribbon from the logic board.
    FixBot'a Sor
    Yorum Ekle
  8. iPod Mini Logic Board Replacement: adım 8, 1 resimden 1.
    • Remove the two #00 Phillips screws securing the headphone jack to the casing.
    FixBot'a Sor
    Yorum Ekle
  9. iPod Mini Logic Board Replacement: adım 9, 1 resimden 1.
    • Carefully slide the iPod out of its casing by pushing on the logic board near the bottom edge of the click wheel.
    • Do not pull on the headphone jack board at the top of the iPod, as the connector to the logic board is fragile.
    FixBot'a Sor
    Yorum Ekle
  10. iPod Mini Logic Board Replacement: adım 10, 1 resimden 1.
    • After pushing the logic board out sufficiently, gently grasp the logic board on either side of the display, and continue to slide the iPod out of its casing.
    FixBot'a Sor
    Yorum Ekle
  11. iPod Mini Logic Board Replacement: adım 11, 1 resimden 1.
    • Lift the battery off of the logic board and lay it to the side of the iPod.
    FixBot'a Sor
    Yorum Ekle
  12. iPod Mini Logic Board Replacement: adım 12, 1 resimden 1.
    • Use a spudger to flip up the black plastic tab holding the orange display ribbon in place. The black tab will rotate up 90 degrees, releasing the ribbon cable.
    • This tab is fragile so be careful not to break it.
    FixBot'a Sor
    Yorum Ekle
  13. iPod Mini Logic Board Replacement: adım 13, 1 resimden 1.
    • Note the location of the four white plastic tabs securing the display to the logic board. These tabs must be released before the display can be removed.
    FixBot'a Sor
    Yorum Ekle
  14. iPod Mini Logic Board Replacement: adım 14, 1 resimden 1.
    • Use a spudger or your finger to free the four white plastic tabs indicated in the previous picture.
    FixBot'a Sor
    Yorum Ekle
  15. iPod Mini Logic Board Replacement: adım 15, 1 resimden 1.
    • Turn the iPod over.
    • Carefully lift the display up and slide it out of its connector.
    FixBot'a Sor
    Yorum Ekle
  16. iPod Mini Logic Board Replacement, Logic Board: adım 16, 1 resimden 1.
    • Use a spudger to carefully pry up the headphone jack board from the logic board. Be careful to pry up near the connector to prevent unnecessary strain on the board.
    FixBot'a Sor
    Yorum Ekle
  17. iPod Mini Logic Board Replacement: adım 17, 1 resimden 1.
    • Carefully disconnect the battery from the logic board. Make sure to pull only on the connector and not on the battery wires.
    FixBot'a Sor
    Yorum Ekle
  18. iPod Mini Logic Board Replacement: adım 18, 1 resimden 1.
    • Use a spudger or the tip of your finger to carefully disconect the orange hard drive ribbon from the logic board.
    • Lift the hard drive out of the iPod.
    FixBot'a Sor
    Yorum Ekle
  19. iPod Mini Logic Board Replacement: adım 19, 1 resimden 1.
    • Logic board remains.
    FixBot'a Sor
    Yorum Ekle
Sonuç
20 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
636 adet Kılavuz yazıldı
1Rehber Yorum
Can You give me a step by step process for reassembling an iPod mini after replacing the logic board. I cannot follow the steps in reverse to reassemble it. Also, is there a youtube video showing the reassambly?
ahmartensson49 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 23
Son 30 gün: 145
Her zaman: 28,094
