Ana içeriğe geç
iPod Mini Top Bezel Replacement
Neye ihtiyacın var
  1. iPod Mini Top Bezel Replacement, Top Bezel: adım 1, 1 resimden 1.
    • Before opening your iPod, ensure that the hold switch is in the locked position.
    FixBot'a Sor
    Yorum Ekle
  2. iPod Mini Top Bezel Replacement: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    Jimmy
    $7.95
    • Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic top. Use the screwdriver to pry up the white plastic top bezel. Be careful not to damage the soft plastic with your screwdriver.
    • The top bezel is held on with an adhesive, so it may be necessary to pry up in several different locations to free the part.
    • To make this job easier, heat up the adhesive with a hairdryer on low heat for a few seconds.
    FixBot'a Sor
    Yorum Ekle
  3. iPod Mini Top Bezel Replacement: adım 3, 1 resimden 1.
    • Lift the top bezel off of the iPod.
    FixBot'a Sor
    Yorum Ekle
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
636 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 26
Son 30 gün: 106
Her zaman: 16,709
