Ana içeriğe geç
iPod Nano 1st Generation Battery & Logic Board Replacement
Neye ihtiyacın var
  1. iPod Nano 1st Generation Battery & Logic Board Replacement, Rear Panel: adım 1, 1 resimden 1.
    • Before opening your iPod, ensure that the hold switch is in the locked position.
    Turn on the notes and READ thru all the steps and the notes, especially the ones involving the ribbon cables.
    patjmccarthy - Yanıt
  2. iPod Nano 1st Generation Battery & Logic Board Replacement: adım 2, 1 resimden 1.
    • The rear panel is secured to the front case by eleven clips permanently attached to the rear panel. These clips lock onto small tabs machined into the front case.
    • To free the tabs, they must be pushed down and away from the iPod's case. Note the location of all tabs on the rear panel. When using an iPod opening tool to free the rear panel, be sure to work the tool at the location of these clips.
  3. iPod Nano 1st Generation Battery & Logic Board Replacement: adım 3, 2 resimden 1. iPod Nano 1st Generation Battery & Logic Board Replacement: adım 3, 2 resimden 2.
    • Opening the iPod can be challenging. Don't get discouraged if it takes you a few tries before the iPod is opened.
    • Insert the large iPod opening tool into the seam between the front case and rear panel of the iPod, below the dock connector. Run the tool back and forth to create an opening. The tool's edge should point toward the rear panel to prevent any accidental scratching of the aluminum front case.
  4. iPod Nano 1st Generation Battery & Logic Board Replacement: adım 4, 1 resimden 1.
    • Insert a small iPod opening tool into the seam on the Hold button side of the iPod, with the edge of the tool pointing toward the rear panel.
  5. iPod Nano 1st Generation Battery & Logic Board Replacement: adım 5, 1 resimden 1.
    • The large iPod opening tool is no longer needed to gain access to the left side of the iPod.
    • Gently enlarge the existing gap by pressing/wiggling the small iPod opening tool into the gap near each of the two tabs attached to the rear case, pushing the clips toward the center of the iPod until both have been freed.
  6. iPod Nano 1st Generation Battery & Logic Board Replacement: adım 6, 3 resimden 1. iPod Nano 1st Generation Battery & Logic Board Replacement: adım 6, 3 resimden 2. iPod Nano 1st Generation Battery & Logic Board Replacement: adım 6, 3 resimden 3.
    • Repeat the same procedure listed in the previous step to free the five clips along the headphone jack side of the iPod.
  7. iPod Nano 1st Generation Battery & Logic Board Replacement: adım 7, 1 resimden 1.
    • After ensuring all tabs are free, separate the two halves of the iPod.
    • The rear panel is now free from the iPod.
  8. iPod Nano 1st Generation Battery & Logic Board Replacement, Battery & Logic Board: adım 8, 1 resimden 1.
    • Remove any kapton tape over the screws, if necessary.
    • Remove the following 3 screws:
    • Two 3 mm Phillips screws near the dock connector.
    • One 4 mm Phillips screw along the edge of the logic board.
    • During reassembly, make sure to put back any tape or plastic you remove. This will prevent any shorts between the logic board and the rear panel. If your tape is unusable, kapton tape can be purchased online.
    Note that the 4mm screw has slightly wider pitch; you'll need this when putting the unit back together.
    daisystanton - Yanıt
  9. iPod Nano 1st Generation Battery & Logic Board Replacement: adım 9, 1 resimden 1.
    • Peel up the ground strap connecting the battery to the logic board.
    The battery ground strap does not have to be replaced. It works fine without it.
    henrymf - Yanıt
  10. iPod Nano 1st Generation Battery & Logic Board Replacement: adım 10, 2 resimden 1. iPod Nano 1st Generation Battery & Logic Board Replacement: adım 10, 2 resimden 2.
    • Insert the flat end of a spudger between the battery and the headphone jack side of the front case to pry the battery up off the adhesive securing it to the front case.
    • Rotate the battery out of the iPod and lay it next to the iPod. The battery is still soldered to the logic board by three wires, so don't remove it entirely.
  11. iPod Nano 1st Generation Battery & Logic Board Replacement: adım 11, 1 resimden 1.
    • Gently lift up on the dock connector end of the logic board to ensure the logic board is free.
  12. iPod Nano 1st Generation Battery & Logic Board Replacement: adım 12, 1 resimden 1.
    • Grasp the end of the logic board near the battery connector with one hand, and hold onto the rest of the iPod with your other hand.
    • Make sure the logic board is lifted slightly above the white plastic notch on the battery side of the board. This notch prevents the board from sliding out in the next step.
    • Slide the logic board out of its holding brackets on the rear of the display.
    • The logic board is still connected to the iPod by two ribbon cables.
    During the disassembly of the board I somehow "delaminated" the display. The result was that the display (after the battery was changed and the device closed again) looked "cloudy". From some angle you couldn't see anything at all anymore. The solution was to heat up the hole device with a hair dryer and rest it on it's front side for about an hour. After that it looked absolutely perfect again. I am not sure whether the heating is really necessary (maybe just lying the ipod on the front side over night would have the same effect) and surely one should be careful to not overheat the device.
    Michael Benner - Yanıt
  13. iPod Nano 1st Generation Battery & Logic Board Replacement: adım 13, 1 resimden 1.
    • Disconnecting the following two ribbon cables may be challenging. To prevent straining the cables or connectors, you can only separate the two halves of the iPod about 1/2 inch during the process.
    • Use a spudger to flip up the black plastic tab holding the orange display ribbon in place. The black tab will rotate up 90 degrees, releasing the ribbon cable.
    Both ribbon cables were especially difficult to put back in. I can't say I succeeded in getting the nano to work again. If you can avoid detaching the cables, do it. If you're replacing the clickwheel, there's no way of avoiding it unfortunately.
    A little tip if you are replacing the screen: Reconnect this ribbon cable from the new screen BEFORE affixing the screen to the adhesive! It will make it much easier. Also be sure that the little black things are UP before trying to put the ribbon in, and make sure you put them DOWN before closing up! The black things on the receptacle "lock" the cable in place, so it is important that you have it STRAIGHT or it wont work. Good luck!
    Schovelbuddy - Yanıt
  14. iPod Nano 1st Generation Battery & Logic Board Replacement: adım 14, 1 resimden 1.
    • Use a spudger to slide the display ribbon out of its connector.
    Getting the display ribbon back in place is the most difficult maneuver in the whole fix. I actually broke the black plastic tab in half while trying to close it back down, (be very gentle with it!). Managed to put the broken half back in(tweezers and patience) and get that ribbon in and put it back down. This battery replacement was the most difficult/tedious repair I have ever done. Don't do it unless you are brave and stubborn.
    checheconleche - Yanıt
    You can leave out this steps with disconnecting the two cables.
    Without disconnecting the two cables, one can separate the two pieces only 1/2 inch. This is enough to work carefully with the soldering iron and change the battery.
    It's a little bit difficult to work with the needle to open the three holes after removing the old battery - but you can do it.
    From the reading of the other notes it seems to me easier than to disconnect the two cables
    cguenther - Yanıt
    Ribbon connectors and absolute ##&&%
    Dan Fitz - Yanıt
  15. iPod Nano 1st Generation Battery & Logic Board Replacement: adım 15, 1 resimden 1.
    • Use a spudger to flip up the black plastic tab holding the orange click wheel ribbon in place. The black tab will rotate up 90 degrees, releasing the ribbon cable.
  16. iPod Nano 1st Generation Battery & Logic Board Replacement: adım 16, 1 resimden 1.
    • Use a spudger to slide the click wheel ribbon out of its connector.
    Don't do this unless you have to. Getting this ribbon back in is nearly impossible.
    daisystanton kullanıcısından alıntı:
    Try using tweezers or medical clamps to reach in that tight spot. Use these tools to also connect the click wheel ribbon back to the logic board.
    Ryan - Yanıt
    Stamp tweezers worked great for the ribbon cable! (Search eBay or Amazon, or your local hobby store.) This would be a useful tool for iFixIt to add to their inventory.
    Michael Lance -
    yeah i just finished puting in a brand new display but it only goes white - no text or anything just white.
    any tips?
    Mabrew - Yanıt
    Mabrew kullanıcısından alıntı:
    any tips?
    Did you ever fix it from white?
    katie - Yanıt
    I wish I had read this thread before trying to remove the ribbons. I was unable to successfully restore these connections after installing the battery. Now my ipod, previously sick, is now dead.
    gregkotis - Yanıt
  17. iPod Nano 1st Generation Battery & Logic Board Replacement: adım 17, 1 resimden 1.
    • The logic board and battery are now free from the iPod.
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
636 adet Kılavuz yazıldı
Bir Yorum
Okay this was really tough for me. Heck give me an iPod video or an iPhone 3 anytime compared to the Nano. I used tweezers as well as a magnifying work lamp, still not an easy task. Just had to remember " Haste makes Waste"
oldturkey03 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 46
Her zaman: 100,928
