Ana içeriğe geç
iPod Nano 2nd Generation Top Bezel Replacement
Neye ihtiyacın var
  1. iPod Nano 2nd Generation Top Bezel Replacement, Top Bezel: adım 1, 1 resimden 1.
    • Before opening your iPod, ensure that the hold switch is in the locked position.
  2. iPod Nano 2nd Generation Top Bezel Replacement: adım 2, 1 resimden 1.
    • Carefully insert an iPod opening tool in the seam between the metal casing and white plastic top.
    • Lift the top bezel off the iPod. It's glued on using a mild adhesive, so some force may be required.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
636 adet Kılavuz yazıldı
2 Yorum
But how do I install it on? Do I just push it back? I want to fix mine but it doesn't even have the top part anymore, or the hold switch
luis - Yanıt
I would recommend that you put some new adhesive on there. All you have to do is put the switch in its place and put on a new top and push it down.
Ad123re -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 26
Her zaman: 18,887
