Ana içeriğe geç
iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement
Neye ihtiyacın var
  1. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement, Rear Case: adım 1, 1 resimden 1.
    • Widen the small gap between the front and rear case by inserting a metal spudger into the gap near the top of the iPod.
    • Be careful when using a metal spudger, as you may scratch the outer case.
  2. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement: adım 2, 2 resimden 1. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement: adım 2, 2 resimden 2.
    • Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case.
  3. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement: adım 3, 1 resimden 1.
    • Insert the iPod Shuffle opening tool into the gap between the front and rear case on the same side, at the bottom corner of the iPod.
    • Pry the rear case away from the front case.
  4. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement: adım 4, 1 resimden 1.
    • Lift the bottom of the rear case and remove it from the rest of the iPod.
  5. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement, Logic Board: adım 5, 1 resimden 1.
    • Disconnect the headphone jack and shuffle switch connector by prying it off the logic board with a spudger.
  6. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement: adım 6, 1 resimden 1.
    • Remove the single Phillips screw securing the logic board to the front case.
  7. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement: adım 7, 1 resimden 1.
    • Peel the battery up from the front case with an iPod opening tool.
    • Remove the logic board and battery from the iPod.
  8. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement, Headphone Jack & Shuffle Switch: adım 8, 1 resimden 1.
    • Pry the headphone jack from the front case with an iPod opening tool.
    • Don't attempt to remove the headphone jack yet, it is connected to the shuffle switch.
  9. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement: adım 9, 1 resimden 1.
    • Using the pointed tip of a spudger, push the shuffle switch in to separate it from the front case.
  10. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement: adım 10, 1 resimden 1.
    • Remove the headphone jack and shuffle switch from the front case.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Matthew Newsom
39.500 İtibar
67 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 11,985
