Giriş
In this replacement guide the user will learn how to disassemble the iRULU down to the logic board, and replace the battery.
Neye ihtiyacın var
Using a Philips head #00 screwdriver locate and remove each of the four screws located along the tall side of the iRulu.
The battery is located right above the logic board, and can be identified as a large flat black rectangle.
Use the plastic opening to scrape away the glue that is holding down the battery.
Bu adımda kullanılan alet:Desoldering Pump$3.99
You should see that the battery is connected by 2 wires, one black and one red that lead to the logic board.
Heat up a soldering iron and melt the solder that is connecting the battery to the logic board.
Completely remove the battery from the device.
Insert the new battery and re-solder the corresponding wires to their respective locations.
2 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Where do you get a new battery
The batteries should be in a holder, not have to unsolder and solder. Most people do not have a soldering iron.
