Ana içeriğe geç
iRobot Braava 320 Battery Replacement
Neye ihtiyacın var
    1. iRobot Braava 320 Battery  Replacement, Battery: adım 1, 1 resimden 1.
      • Flip your device over and locate the battery cover.
      • The battery cover is located in the center of the device in between both wheels.
      FixBot'a Sor
      Yorum Ekle
    2. iRobot Braava 320 Battery  Replacement: adım 2, 1 resimden 1.
      • Using a Flathead #4 screwdriver, gently turn the 12mm screw that holds the battery cover in.
      • The screw does not remove, it stays attached to the cover.
      FixBot'a Sor
      Yorum Ekle
    3. iRobot Braava 320 Battery  Replacement: adım 3, 2 resimden 1. iRobot Braava 320 Battery  Replacement: adım 3, 2 resimden 2.
      • Gently remove the battery from the tray and disconnect the battery cable.
      • To remove the battery, pull it straight up. To disconnect the cable, gently pull it straight out of the connector.
      • To reinstall the cable, hold it near the end and gently push it in the connector.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
bradley boardwine
222 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G3, Nance Spring 2017 USF Tampa, Team S1-G3, Nance Spring 2017 üyesi
USFT-NANCE-S17S1G3
4 Üyeler
15 adet Kılavuz yazıldı
1Rehber Yorum
where do I get a new battery from?
j.svetlova - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 33
Her zaman: 5,159
