Ana içeriğe geç
iRobot Braava 320 Deck Plate Arms Replacement
Neye ihtiyacın var
  1. iRobot Braava 320 Deck Plate Arms Replacement, Battery: adım 1, 1 resimden 1.
    • Flip your device over and locate the battery cover.
    • The battery cover is located in the center of the device in between both wheels.
  2. iRobot Braava 320 Deck Plate Arms Replacement: adım 2, 1 resimden 1.
    • Using a Flathead #4 screwdriver, gently turn the 12mm screw that holds the battery cover in.
    • The screw does not remove, it stays attached to the cover.
  3. iRobot Braava 320 Deck Plate Arms Replacement: adım 3, 2 resimden 1. iRobot Braava 320 Deck Plate Arms Replacement: adım 3, 2 resimden 2.
    • Gently remove the battery from the tray and disconnect the battery cable.
    • To remove the battery, pull it straight up. To disconnect the cable, gently pull it straight out of the connector.
    • To reinstall the cable, hold it near the end and gently push it in the connector.
  4. iRobot Braava 320 Deck Plate Arms Replacement, Body Shell and Control Panel: adım 4, 1 resimden 1.
    • With the battery removed, rotate your device so the front of it is facing you.
    • Remove the four 10mm Phillips #2 screws that attach the shell.
  5. iRobot Braava 320 Deck Plate Arms Replacement: adım 5, 2 resimden 1. iRobot Braava 320 Deck Plate Arms Replacement: adım 5, 2 resimden 2.
    • Using both hands, hold the device together while you flip it over.
    • Starting from the front, gently lift up the shell and slowly tilt back until it is fully removed.
  6. iRobot Braava 320 Deck Plate Arms Replacement, Deck Plate Assembly: adım 6, 1 resimden 1.
    • With the shell off, flip the iRobot over and remove the four 10mm Phillips #0 screws holding the deck plate assembly on.
  7. iRobot Braava 320 Deck Plate Arms Replacement: adım 7, 3 resimden 1. iRobot Braava 320 Deck Plate Arms Replacement: adım 7, 3 resimden 2. iRobot Braava 320 Deck Plate Arms Replacement: adım 7, 3 resimden 3.
    • Remove the two 12mm Phillips #0 screws that hold the two springs onto the deck plate assembly.
    • Remove the two springs by gently lifting them up.
  8. iRobot Braava 320 Deck Plate Arms Replacement: adım 8, 1 resimden 1.
    • Flip the device over and remove the deck plate assembly cover by lifting it up.
  9. iRobot Braava 320 Deck Plate Arms Replacement: adım 9, 1 resimden 1.
    • Pull the arms together by lifting them up and to the center.
    • With the arms together. slide the deck plate up and over the arms until it is fully removed.
  10. iRobot Braava 320 Deck Plate Arms Replacement, Deck Plate Arms: adım 10, 1 resimden 1.
    • With the deck plate off, remove the three 10mm Phillips #2 screw
  11. iRobot Braava 320 Deck Plate Arms Replacement: adım 11, 2 resimden 1. iRobot Braava 320 Deck Plate Arms Replacement: adım 11, 2 resimden 2.
    • Be careful when removing the arms, do not lose the springs located under the arms.
Sonuç
Amroo
101 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G3, Nance Spring 2017 USF Tampa, Team S1-G3, Nance Spring 2017 üyesi
USFT-NANCE-S17S1G3
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 618
