Ana içeriğe geç
iRobot Braava 320 Wheel Replacement
Neye ihtiyacın var
    1. iRobot Braava 320 Wheel Replacement, Battery: adım 1, 1 resimden 1.
      • Flip your device over and locate the battery cover.
      • The battery cover is located in the center of the device in between both wheels.
      FixBot'a Sor
      Yorum Ekle
    2. iRobot Braava 320 Wheel Replacement: adım 2, 1 resimden 1.
      • Using a Flathead #4 screwdriver, gently turn the 12mm screw that holds the battery cover in.
      • The screw does not remove, it stays attached to the cover.
      FixBot'a Sor
      Yorum Ekle
    3. iRobot Braava 320 Wheel Replacement: adım 3, 2 resimden 1. iRobot Braava 320 Wheel Replacement: adım 3, 2 resimden 2.
      • Gently remove the battery from the tray and disconnect the battery cable.
      • To remove the battery, pull it straight up. To disconnect the cable, gently pull it straight out of the connector.
      • To reinstall the cable, hold it near the end and gently push it in the connector.
      FixBot'a Sor
      Yorum Ekle
    1. iRobot Braava 320 Wheel Replacement, Body Shell and Control Panel: adım 4, 1 resimden 1.
      • With the battery removed, rotate your device so the front of it is facing you.
      • Remove the four 10mm Phillips #2 screws that attach the shell.
      FixBot'a Sor
      Yorum Ekle
    2. iRobot Braava 320 Wheel Replacement: adım 5, 2 resimden 1. iRobot Braava 320 Wheel Replacement: adım 5, 2 resimden 2.
      • Using both hands, hold the device together while you flip it over.
      • Starting from the front, gently lift up the shell and slowly tilt back until it is fully removed.
      FixBot'a Sor
      Yorum Ekle
    1. iRobot Braava 320 Wheel Replacement, Wheel: adım 6, 3 resimden 1. iRobot Braava 320 Wheel Replacement, Wheel: adım 6, 3 resimden 2. iRobot Braava 320 Wheel Replacement, Wheel: adım 6, 3 resimden 3.
      • To remove the wheel covers, hold the wheel in place with one hand while turning the cover clock-wise with the other.
      • The cover should come off as soon as you hear a 'click' sound.
      • When replacing the cover, align the notches on the cover just to the right of the ones on the wheel.
      FixBot'a Sor
      Yorum Ekle
    2. iRobot Braava 320 Wheel Replacement: adım 7, 3 resimden 1. iRobot Braava 320 Wheel Replacement: adım 7, 3 resimden 2. iRobot Braava 320 Wheel Replacement: adım 7, 3 resimden 3.
      • Using a small Flathead screwdriver, remove the small black clip in the center of the wheel.
      • To ensure the clip does not fly off, place your hand over the wheel to cover it as you remove the clip.
      FixBot'a Sor
      Yorum Ekle
    3. iRobot Braava 320 Wheel Replacement: adım 8, 3 resimden 1. iRobot Braava 320 Wheel Replacement: adım 8, 3 resimden 2. iRobot Braava 320 Wheel Replacement: adım 8, 3 resimden 3.
      • Once the small black clip is removed, the wheel should come off by gently pulling on it.
      • Be careful not to lose the two small chrome pieces located on each side of the wheel.
      FixBot'a Sor
      Yorum Ekle
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Ekip
USF Tampa, Team S1-G3, Nance Spring 2017 USF Tampa, Team S1-G3, Nance Spring 2017 üyesi
USFT-NANCE-S17S1G3
4 Üyeler
15 adet Kılavuz yazıldı
1Rehber Yorum
O roteiro descritivo para a troca das rodas do Braava foi muito útil. Obrigada!
Vanilda Chueiri - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 33
Her zaman: 10,702
