Giriş
Without properly functioning wheels, the Braava will have a difficult time navigating. This will lead to inefficient sweeping or mopping. This guide will show how to replace the Braava's wheels.
Neye ihtiyacın var
With the battery removed, rotate your device so the front of it is facing you.
Remove the four 10mm Phillips #2 screws that attach the shell.
To remove the wheel covers, hold the wheel in place with one hand while turning the cover clock-wise with the other.
13 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
O roteiro descritivo para a troca das rodas do Braava foi muito útil. Obrigada!
