Ana içeriğe geç
iRobot Braava 375t Battery Replacement
Neye ihtiyacın var
    1. iRobot Braava 375t Battery Replacement, Battery: adım 1, 1 resimden 1.
      • Turn the device over upside down and locate the battery panel.
      • The panel has a symbol of a trash can crossed out.
      FixBot'a Sor
      Yorum Ekle
    2. iRobot Braava 375t Battery Replacement: adım 2, 1 resimden 1.
      • After locating the panel, locate the screw (should be around the top center).
      • You will need a medium sized flathead screwdriver to loosen the screw.
      FixBot'a Sor
      Yorum Ekle
    3. iRobot Braava 375t Battery Replacement: adım 3, 1 resimden 1.
      • Insert the screwdriver and turn counter clockwise (left) to loosen the screw.
      • You may need to apply pressure when turning if the screw is tight.
      FixBot'a Sor
      Yorum Ekle
    4. iRobot Braava 375t Battery Replacement: adım 4, 2 resimden 1. iRobot Braava 375t Battery Replacement: adım 4, 2 resimden 2.
      • Once the screw is completely taken off, remove the panel to reveal the battery.
      • The battery will have a wire, follow the wire which will lead to a plastic white clip (pin). Pull the wire clip upwards carefully until the all pins are separated.
      • Use a small screwdriver and wedge the head between the clips if the pins are tight.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jadealyn Paulino
275 İtibar
1 Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 5-5, Adachi Fall 2022 CSU Los Angeles, Team 5-5, Adachi Fall 2022 üyesi
CSULA-ADACHI-F22S5G5
6 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 33
Her zaman: 440
