Ana içeriğe geç
iRobot Braava Jet 240 Back Shell Replacement
Neye ihtiyacın var
  1. iRobot Braava Jet 240 Back Shell Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the device off.
  2. iRobot Braava Jet 240 Back Shell Replacement: adım 2, 2 resimden 1. iRobot Braava Jet 240 Back Shell Replacement: adım 2, 2 resimden 2.
    • Use your fingers to gently pop out the battery.
  3. iRobot Braava Jet 240 Back Shell Replacement, Mop Pad: adım 3, 2 resimden 1. iRobot Braava Jet 240 Back Shell Replacement, Mop Pad: adım 3, 2 resimden 2.
    • Lift up the handle to reveal the eject button.
  4. iRobot Braava Jet 240 Back Shell Replacement: adım 4, 3 resimden 1. iRobot Braava Jet 240 Back Shell Replacement: adım 4, 3 resimden 2. iRobot Braava Jet 240 Back Shell Replacement: adım 4, 3 resimden 3.
    • Use your finger to push the eject button forward.
  5. iRobot Braava Jet 240 Back Shell Replacement: adım 5, 1 resimden 1.
    • Tilt the robot on its side and let the mop pad slide out.
  6. iRobot Braava Jet 240 Back Shell Replacement, Front Shell: adım 6, 2 resimden 1. iRobot Braava Jet 240 Back Shell Replacement, Front Shell: adım 6, 2 resimden 2.
    • Remove the two 22.0 mm screws on the bottom-front of the robot using a Phillips #1 screwdriver.
  7. iRobot Braava Jet 240 Back Shell Replacement: adım 7, 2 resimden 1. iRobot Braava Jet 240 Back Shell Replacement: adım 7, 2 resimden 2.
    • Use a Phillips #1 screwdriver and an iFixit opening tool to remove the two 15.0 mm screws on the front sides of the robot.
  8. iRobot Braava Jet 240 Back Shell Replacement: adım 8, 3 resimden 1. iRobot Braava Jet 240 Back Shell Replacement: adım 8, 3 resimden 2. iRobot Braava Jet 240 Back Shell Replacement: adım 8, 3 resimden 3.
    • Carefully pull back on the front shell to remove it from the robot.
  9. iRobot Braava Jet 240 Back Shell Replacement, Back Shell: adım 9, 2 resimden 1. iRobot Braava Jet 240 Back Shell Replacement, Back Shell: adım 9, 2 resimden 2.
    • Insert a Phillips #1 screwdriver through the screw holes.
    • Unscrew the two 9.7 mm screws.
  10. iRobot Braava Jet 240 Back Shell Replacement: adım 10, 2 resimden 1. iRobot Braava Jet 240 Back Shell Replacement: adım 10, 2 resimden 2.
    • Unscrew the four 9.7 mm screws using a long neck #1 Phillips screwdriver.
    • If the screws are unscrewed but do not come out easily, turn the robot upside down and gently shake it.
  11. iRobot Braava Jet 240 Back Shell Replacement: adım 11, 3 resimden 1. iRobot Braava Jet 240 Back Shell Replacement: adım 11, 3 resimden 2. iRobot Braava Jet 240 Back Shell Replacement: adım 11, 3 resimden 3.
    • Pull up on the back shell to remove it from the robot.
    • For reassembly, pop the mop pad release trigger back into place if it fell out during back shell removal.
Sonuç
Claire Franz
2.772 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S22-G2, Regan Winter 2020 Cal Poly, Team S22-G2, Regan Winter 2020 üyesi
CPSU-REGAN-W20S22G2
5 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 1,130
