Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
The front shell of the iRobot Braava Jet 240 covers all of the device’s circuitry as well as the nozzle. Therefore, to replace the nozzle, the front shell must first be removed. Follow this guide to remove the front shell.
Parçalar
Hiçbir parça belirtilmedi.
  1. Turn the device off.
    • Turn the device off.
  2. Use your fingers to gently pop out the battery. Use your fingers to gently pop out the battery.
    • Use your fingers to gently pop out the battery.
  3. Lift up the handle to reveal the eject button. Lift up the handle to reveal the eject button.
    • Lift up the handle to reveal the eject button.
  4. Use your finger to push the eject button forward. Use your finger to push the eject button forward. Use your finger to push the eject button forward.
    • Use your finger to push the eject button forward.
  5. Tilt the robot on its side and let the mop pad slide out.
    • Tilt the robot on its side and let the mop pad slide out.
  6. Remove the two 22.0  mm screws on the bottom-front of the robot using a Phillips #1 screwdriver. Remove the two 22.0  mm screws on the bottom-front of the robot using a Phillips #1 screwdriver.
    • Remove the two 22.0 mm screws on the bottom-front of the robot using a Phillips #1 screwdriver.
  7. Use a Phillips #1 screwdriver and an iFixit opening tool to remove the two 15.0 mm screws on the front sides of the robot. Use a Phillips #1 screwdriver and an iFixit opening tool to remove the two 15.0 mm screws on the front sides of the robot.
    • Use a Phillips #1 screwdriver and an iFixit opening tool to remove the two 15.0 mm screws on the front sides of the robot.
  8. Carefully pull back on the front shell to remove it from the robot. Carefully pull back on the front shell to remove it from the robot. Carefully pull back on the front shell to remove it from the robot.
    • Carefully pull back on the front shell to remove it from the robot.
Sonuç
Claire Franz
1.355 İtibar
7 adet Kılavuz yazıldı
Takım
Cal Poly, Team S22-G2, Regan Winter 2020 Cal Poly, Team S22-G2, Regan Winter 2020 üyesi
CPSU-REGAN-W20S22G2
5 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 16
Her zaman: 141
