Ana içeriğe geç
iRobot Braava Jet 240 Wheel Replacement
Neye ihtiyacın var
    1. iRobot Braava Jet 240 Wheel Replacement, Battery: adım 1, 1 resimden 1.
      • Turn the device off.
      FixBot'a Sor
      Yorum Ekle
    2. iRobot Braava Jet 240 Wheel Replacement: adım 2, 2 resimden 1. iRobot Braava Jet 240 Wheel Replacement: adım 2, 2 resimden 2.
      • Use your fingers to gently pop out the battery.
      FixBot'a Sor
      Yorum Ekle
    1. iRobot Braava Jet 240 Wheel Replacement, Mop Pad: adım 3, 2 resimden 1. iRobot Braava Jet 240 Wheel Replacement, Mop Pad: adım 3, 2 resimden 2.
      • Lift up the handle to reveal the eject button.
      FixBot'a Sor
      Yorum Ekle
    2. iRobot Braava Jet 240 Wheel Replacement: adım 4, 3 resimden 1. iRobot Braava Jet 240 Wheel Replacement: adım 4, 3 resimden 2. iRobot Braava Jet 240 Wheel Replacement: adım 4, 3 resimden 3.
      • Use your finger to push the eject button forward.
      FixBot'a Sor
      Yorum Ekle
    3. iRobot Braava Jet 240 Wheel Replacement: adım 5, 1 resimden 1.
      • Tilt the robot on its side and let the mop pad slide out.
      FixBot'a Sor
      Yorum Ekle
    1. iRobot Braava Jet 240 Wheel Replacement, Wheel: adım 6, 2 resimden 1. iRobot Braava Jet 240 Wheel Replacement, Wheel: adım 6, 2 resimden 2.
      • Using your thumbs, first push back the motor assembly, then push up.
      FixBot'a Sor
      Yorum Ekle
    2. iRobot Braava Jet 240 Wheel Replacement: adım 7, 2 resimden 1. iRobot Braava Jet 240 Wheel Replacement: adım 7, 2 resimden 2.
      • Remove the 11.55 mm screws in the middle of both wheels using the Phillips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. iRobot Braava Jet 240 Wheel Replacement: adım 8, 3 resimden 1. iRobot Braava Jet 240 Wheel Replacement: adım 8, 3 resimden 2. iRobot Braava Jet 240 Wheel Replacement: adım 8, 3 resimden 3.
      • Pull the wheel off from the axel, pulling from the top end first so it can slide out at an angle.
      • It will be easier to remove the wheels if the motor assembly is tilted so that the wheel that you are removing is elevated.
      FixBot'a Sor
      Yorum Ekle
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Claire Franz
2.805 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S22-G2, Regan Winter 2020 Cal Poly, Team S22-G2, Regan Winter 2020 üyesi
CPSU-REGAN-W20S22G2
5 Üyeler
20 adet Kılavuz yazıldı
7Kılavuz Yorumları
Thank you so much!
Michaela - Yanıt Paylaş
Where can I get the replacement wheels?
John
john - Yanıt Paylaş
iRobot does not sell replacement parts for the 240, other than things like batteries. I look for dead As-Is units on eBay and buy them to scavenge parts. (And it really irks me that iRobot doesn't sell the parts!)
William Fickas - Yanıt Paylaş
Thanks, William Fickas! I wish I knew this when I bought my 240. Selling their product but not keeping long term customers happy seems to be this company's mantra.
ejhcornelisse - Yanıt Paylaş
Followed the guide and a spring fell out!? It has 5 turns and about 1" long with a 3/16" loop on one end? I'm thinking that I lifted the wheel assembly up just a bit too high. Any idea where that spring came from? Maybe somewhere in the middle of the assemble? Other than that the guide is perfect! Thank you and keep up the good work!
Bob Read - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 30
Son 30 gün: 106
Her zaman: 10,912
