Ana içeriğe geç
iRobot Roomba 4100 Battery Pack Replacement
Neye ihtiyacın var
    1. iRobot Roomba 4100 Battery Pack Replacement, Battery Pack: adım 1, 1 resimden 1.
      • Turn the Roomba upside down to be able to see the yellow battery pack.
      FixBot'a Sor
      Yorum Ekle
    2. iRobot Roomba 4100 Battery Pack Replacement: adım 2, 2 resimden 1. iRobot Roomba 4100 Battery Pack Replacement: adım 2, 2 resimden 2.
      • Remove the battery by placing your fingers into the two holes and firmly press your fingers against both sides of the battery.
      • Lift the battery directly up and out of the device.
      FixBot'a Sor
      Yorum Ekle
    3. iRobot Roomba 4100 Battery Pack Replacement: adım 3, 1 resimden 1.
      • Line up the replacement battery’s larger tab side with the larger tab hole and the smaller tab side with the smaller tab hole.
      • Insert the replacement battery into the empty space and firmly press down onto the battery until two audible clicks are heard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Your iRobot Roomba 4100 is now ready for use.
2 farklı kişi bu kılavuzu tamamladı.
Scott Leonard
445 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-6, Maness Fall 2010 Cal Poly, Team 20-6, Maness Fall 2010 üyesi
CPSU-MANESS-F10S20G6
2 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 39
Her zaman: 8,981
