Ana içeriğe geç
iRobot Roomba 4160 Brush Guard Replacement
  1. iRobot Roomba 4160 Brush Guard Replacement, Brush Guard: adım 1, 1 resimden 1.
    • Make sure the Roomba is turned off to prevent injury.
    • Turn the Roomba upside down so that the underside is exposed. The wheels and brushes should be visible.
    • Identify the brush guard, which is the black rectangular frame that the metal rods are attached to.
  2. iRobot Roomba 4160 Brush Guard Replacement: adım 2, 1 resimden 1.
    • Locate the 2 small rectangular yellow tabs on either side of the brush guard, directly adjacent to the blue flap.
    • Place index fingers on both tabs, and apply slight pressure in the direction of the yellow battery pack.
    • While you are applying pressure, the guard should hinge up in the direction of the yellow battery pack.
  3. iRobot Roomba 4160 Brush Guard Replacement: adım 3, 2 resimden 1. iRobot Roomba 4160 Brush Guard Replacement: adım 3, 2 resimden 2.
    • After the guard hinges up, lift the guard up and away from the Roomba.
Sonuç
Philippe Napaa
222 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-4, Forte Spring 2014 Cal Poly, Team 6-4, Forte Spring 2014 üyesi
CPSU-FORTE-S14S6G4
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 7
Her zaman: 296
