Ana içeriğe geç
iRobot Roomba 551 Battery Replacement
Neye ihtiyacın var
  1. iRobot Roomba 551  Battery Replacement, Side Brush: adım 1, 1 resimden 1.
    • Place your Roomba upside-down on a hard surface.
    FixBot'a Sor
    Yorum Ekle
  2. iRobot Roomba 551  Battery Replacement: adım 2, 1 resimden 1.
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
    FixBot'a Sor
    Yorum Ekle
  3. iRobot Roomba 551  Battery Replacement: adım 3, 1 resimden 1.
    • Gently pull upwards on the brush to remove it.
    FixBot'a Sor
    Yorum Ekle
  4. iRobot Roomba 551  Battery Replacement, Bottom Plate: adım 4, 1 resimden 1.
    • Rotate the Roomba upside-down so the bottom is facing towards you.
    FixBot'a Sor
    Yorum Ekle
  5. iRobot Roomba 551  Battery Replacement: adım 5, 2 resimden 1. iRobot Roomba 551  Battery Replacement: adım 5, 2 resimden 2.
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
    FixBot'a Sor
    Yorum Ekle
  6. iRobot Roomba 551  Battery Replacement: adım 6, 1 resimden 1.
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
    FixBot'a Sor
    Yorum Ekle
  7. iRobot Roomba 551  Battery Replacement, Battery: adım 7, 2 resimden 1. iRobot Roomba 551  Battery Replacement, Battery: adım 7, 2 resimden 2.
    • Lift and remove the old battery by pulling the tabs on both sides.
    • Gently replace with a new battery.
    FixBot'a Sor
    Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Deborah Newberry
623 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-14, Regan Winter 2014 Cal Poly, Team 13-14, Regan Winter 2014 üyesi
CPSU-REGAN-W14S13G14
4 Üyeler
32 adet Kılavuz yazıldı
1Rehber Yorum
Thank you Deborah!
James - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 24
Son 30 gün: 88
Her zaman: 11,990
