Ana içeriğe geç
iRobot Roomba 551 Brushes Replacement
Neye ihtiyacın var
  1. iRobot Roomba 551 Brushes Replacement, Side Brush: adım 1, 1 resimden 1.
    • Place your Roomba upside-down on a hard surface.
    FixBot'a Sor
  2. iRobot Roomba 551 Brushes Replacement: adım 2, 1 resimden 1.
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
    FixBot'a Sor
  3. iRobot Roomba 551 Brushes Replacement: adım 3, 1 resimden 1.
    • Gently pull upwards on the brush to remove it.
    FixBot'a Sor
  4. iRobot Roomba 551 Brushes Replacement, Bottom Plate: adım 4, 1 resimden 1.
    • Rotate the Roomba upside-down so the bottom is facing towards you.
    FixBot'a Sor
  5. iRobot Roomba 551 Brushes Replacement: adım 5, 2 resimden 1. iRobot Roomba 551 Brushes Replacement: adım 5, 2 resimden 2.
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
    FixBot'a Sor
  6. iRobot Roomba 551 Brushes Replacement: adım 6, 1 resimden 1.
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
    FixBot'a Sor
  7. iRobot Roomba 551 Brushes Replacement, Brushes: adım 7, 2 resimden 1. iRobot Roomba 551 Brushes Replacement, Brushes: adım 7, 2 resimden 2.
    • Pinch the yellow tabs on the sides of the brush cage and lift up to open.
    FixBot'a Sor
  8. iRobot Roomba 551 Brushes Replacement: adım 8, 3 resimden 1. iRobot Roomba 551 Brushes Replacement: adım 8, 3 resimden 2. iRobot Roomba 551 Brushes Replacement: adım 8, 3 resimden 3.
    • Grab each brush and lift upwards to remove.
    FixBot'a Sor
Sonuç
John McTigue
331 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-14, Regan Winter 2014 Cal Poly, Team 13-14, Regan Winter 2014 üyesi
CPSU-REGAN-W14S13G14
4 Üyeler
19 adet Kılavuz yazıldı
2Kılavuz Yorumları
Should be no need to remove the back plate. Just open the brush cage and lift out the brushes
Gunnar Nybraten - Yanıt Paylaş
I did all that, bought a new brush cage and it is still announcing error 2-clean brushes.
Christa Eads - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 20
Son 30 gün: 131
Her zaman: 10,282
