Ana içeriğe geç
iRobot Roomba 551 Bumper Sensor Replacement
Neye ihtiyacın var
  1. iRobot Roomba 551 Bumper Sensor Replacement, Side Brush: adım 1, 1 resimden 1.
    • Place your Roomba upside-down on a hard surface.
  2. iRobot Roomba 551 Bumper Sensor Replacement: adım 2, 1 resimden 1.
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. iRobot Roomba 551 Bumper Sensor Replacement: adım 3, 1 resimden 1.
    • Gently pull upwards on the brush to remove it.
  4. iRobot Roomba 551 Bumper Sensor Replacement, Bottom Plate: adım 4, 1 resimden 1.
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. iRobot Roomba 551 Bumper Sensor Replacement: adım 5, 2 resimden 1. iRobot Roomba 551 Bumper Sensor Replacement: adım 5, 2 resimden 2.
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. iRobot Roomba 551 Bumper Sensor Replacement: adım 6, 1 resimden 1.
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  7. iRobot Roomba 551 Bumper Sensor Replacement, Bumper: adım 7, 3 resimden 1. iRobot Roomba 551 Bumper Sensor Replacement, Bumper: adım 7, 3 resimden 2. iRobot Roomba 551 Bumper Sensor Replacement, Bumper: adım 7, 3 resimden 3.
    • With a Phillips #1 screwdriver, remove the ten 12mm screws located along the bottom of the bumper.
  8. iRobot Roomba 551 Bumper Sensor Replacement: adım 8, 1 resimden 1.
    • Lift the bottom cover and set it to the side.
  9. iRobot Roomba 551 Bumper Sensor Replacement: adım 9, 2 resimden 1. iRobot Roomba 551 Bumper Sensor Replacement: adım 9, 2 resimden 2.
    • Flip the Roomba over, grasp the bumper, and gently lift to remove.
    • The battery is not secured in place once the bottom plate has been removed, and may fall out when the Roomba is turned right-side up.
  10. iRobot Roomba 551 Bumper Sensor Replacement, Bumper Sensor: adım 10, 1 resimden 1.
    • Flip the Roomba so that the bottom is facing you.
  11. iRobot Roomba 551 Bumper Sensor Replacement: adım 11, 2 resimden 1. iRobot Roomba 551 Bumper Sensor Replacement: adım 11, 2 resimden 2.
    • Remove the two 5mm screws located near the center of the bumper using a Phillips #1 screwdriver.
  12. iRobot Roomba 551 Bumper Sensor Replacement: adım 12, 1 resimden 1.
    • Pull gently on the bottom of the sensor to remove.
  13. iRobot Roomba 551 Bumper Sensor Replacement: adım 13, 3 resimden 1. iRobot Roomba 551 Bumper Sensor Replacement: adım 13, 3 resimden 2. iRobot Roomba 551 Bumper Sensor Replacement: adım 13, 3 resimden 3.
    • Flip the bumper over and lift the sensor from its compartment.
    • You are now free to replace the bumper sensor.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Cody Rhoads
348 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-14, Regan Winter 2014 Cal Poly, Team 13-14, Regan Winter 2014 üyesi
CPSU-REGAN-W14S13G14
4 Üyeler
19 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 4,655
