Giriş
This guide explains how to remove the main brush motor from your Roomba.
Neye ihtiyacın var
Push on the dirt bin release button, and pull gently.
Use a Phillips #1 screwdriver to loosen the 4 captive screws around the case .
Use a Phillips #1 screwdriver to remove the 9.5mm screws from the side of the brush case, and pull to detach.
Repeat for the opposite side of the brush case.
2 farklı kişi bu kılavuzu tamamladı.
