Ana içeriğe geç
iRobot Roomba 551 Side Wheel Replacement
Neye ihtiyacın var
  1. iRobot Roomba 551 Side Wheel Replacement, Side Brush: adım 1, 1 resimden 1.
    • Place your Roomba upside-down on a hard surface.
    FixBot'a Sor
    Yorum Ekle
  2. iRobot Roomba 551 Side Wheel Replacement: adım 2, 1 resimden 1.
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
    FixBot'a Sor
    Yorum Ekle
  3. iRobot Roomba 551 Side Wheel Replacement: adım 3, 1 resimden 1.
    • Gently pull upwards on the brush to remove it.
    FixBot'a Sor
    Yorum Ekle
  4. iRobot Roomba 551 Side Wheel Replacement, Bottom Plate: adım 4, 1 resimden 1.
    • Rotate the Roomba upside-down so the bottom is facing towards you.
    FixBot'a Sor
    Yorum Ekle
  5. iRobot Roomba 551 Side Wheel Replacement: adım 5, 2 resimden 1. iRobot Roomba 551 Side Wheel Replacement: adım 5, 2 resimden 2.
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
    FixBot'a Sor
    Yorum Ekle
  6. iRobot Roomba 551 Side Wheel Replacement: adım 6, 1 resimden 1.
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
    FixBot'a Sor
    Yorum Ekle
  7. iRobot Roomba 551 Side Wheel Replacement, Side Wheel: adım 7, 3 resimden 1. iRobot Roomba 551 Side Wheel Replacement, Side Wheel: adım 7, 3 resimden 2. iRobot Roomba 551 Side Wheel Replacement, Side Wheel: adım 7, 3 resimden 3.
    • Find the blue wheel at the bottom of the Roomba, and unscrew the three captive screws holding it in place using a Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  8. iRobot Roomba 551 Side Wheel Replacement: adım 8, 2 resimden 1. iRobot Roomba 551 Side Wheel Replacement: adım 8, 2 resimden 2.
    • Gently lift the wheel to remove.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Deborah Newberry
623 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-14, Regan Winter 2014 Cal Poly, Team 13-14, Regan Winter 2014 üyesi
CPSU-REGAN-W14S13G14
4 Üyeler
32 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 44
Her zaman: 1,748
