Ana içeriğe geç
iRobot Roomba 560 Fan Replacement
Neye ihtiyacın var
    1. iRobot Roomba 560 Fan Replacement, Fan: adım 1, 1 resimden 1.
      • Press the black circular button on the back end of the Roomba and pull the bin out towards you to remove the vacuum bin.
      FixBot'a Sor
      Yorum Ekle
    2. iRobot Roomba 560 Fan Replacement: adım 2, 2 resimden 1. iRobot Roomba 560 Fan Replacement: adım 2, 2 resimden 2.
      • Lay the vacuum bin down and remove the six 15 mm screws around the outside of the vacuum bin using the Phillips JIS #1 driver.
      • Remove the top of the vacuum bin by pulling it straight up.
      • The bin is composed of two parts (the clear top casing and the red bottom filter). To avoid a mess, be careful to not let these two pieces detach, unless over a trash bin.
      FixBot'a Sor
      Yorum Ekle
    3. iRobot Roomba 560 Fan Replacement: adım 3, 3 resimden 1. iRobot Roomba 560 Fan Replacement: adım 3, 3 resimden 2. iRobot Roomba 560 Fan Replacement: adım 3, 3 resimden 3.
      • Remove the three 10 mm screws that surround the fan using the Phillips JIS #1 driver.
      • Remove the casing that surrounds the fan by pulling it straight up.
      • The casing is composed of 2 parts (the large top casing, and a small air filter). If these parts detach, they are very easy to put back together. Do not lose the air filter.
      FixBot'a Sor
      Yorum Ekle
    4. iRobot Roomba 560 Fan Replacement: adım 4, 3 resimden 1. iRobot Roomba 560 Fan Replacement: adım 4, 3 resimden 2. iRobot Roomba 560 Fan Replacement: adım 4, 3 resimden 3.
      • Turn over the remainder of the fan casing and remove the single 15mm screw, using the Phillips JIS #1 screwdriver.
      • Remove the casing from the fan and battery component by pulling it straight up.
      FixBot'a Sor
      Yorum Ekle
    5. iRobot Roomba 560 Fan Replacement: adım 5, 1 resimden 1.
      • Remove the small black button from the top of the battery.
      • Save the spring and the button cover. The remainder of the fan assembly (yellow motor and the black housing) will need to be replaced as a unit.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
TJ Tamura
289 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 1-22, Maness Fall 2015 Cal Poly, Team 1-22, Maness Fall 2015 üyesi
CPSU-MANESS-F15S1G22
4 Üyeler
21 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 53
Her zaman: 5,288
