Ana içeriğe geç
iRobot Roomba 560 Fan Replacement
Neye ihtiyacın var
  1. iRobot Roomba 560 Fan Replacement, Fan: adım 1, 1 resimden 1.
    • Press the black circular button on the back end of the Roomba and pull the bin out towards you to remove the vacuum bin.
  2. iRobot Roomba 560 Fan Replacement: adım 2, 2 resimden 1. iRobot Roomba 560 Fan Replacement: adım 2, 2 resimden 2.
    • Lay the vacuum bin down and remove the six 15 mm screws around the outside of the vacuum bin using the Phillips JIS #1 driver.
    • Remove the top of the vacuum bin by pulling it straight up.
    • The bin is composed of two parts (the clear top casing and the red bottom filter). To avoid a mess, be careful to not let these two pieces detach, unless over a trash bin.
  3. iRobot Roomba 560 Fan Replacement: adım 3, 3 resimden 1. iRobot Roomba 560 Fan Replacement: adım 3, 3 resimden 2. iRobot Roomba 560 Fan Replacement: adım 3, 3 resimden 3.
    • Remove the three 10 mm screws that surround the fan using the Phillips JIS #1 driver.
    • Remove the casing that surrounds the fan by pulling it straight up.
    • The casing is composed of 2 parts (the large top casing, and a small air filter). If these parts detach, they are very easy to put back together. Do not lose the air filter.
  4. iRobot Roomba 560 Fan Replacement: adım 4, 3 resimden 1. iRobot Roomba 560 Fan Replacement: adım 4, 3 resimden 2. iRobot Roomba 560 Fan Replacement: adım 4, 3 resimden 3.
    • Turn over the remainder of the fan casing and remove the single 15mm screw, using the Phillips JIS #1 screwdriver.
    • Remove the casing from the fan and battery component by pulling it straight up.
  5. iRobot Roomba 560 Fan Replacement: adım 5, 1 resimden 1.
    • Remove the small black button from the top of the battery.
    • Save the spring and the button cover. The remainder of the fan assembly (yellow motor and the black housing) will need to be replaced as a unit.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
TJ Tamura
289 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 1-22, Maness Fall 2015 Cal Poly, Team 1-22, Maness Fall 2015 üyesi
CPSU-MANESS-F15S1G22
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 27
Her zaman: 4,595
