Ana içeriğe geç
iRobot Roomba 560 Motherboard Replacement
Neye ihtiyacın var
  1. iRobot Roomba 560 Motherboard Replacement, Start: adım 1, 1 resimden 1.
    • Rotate the Roomba so the bumper is in front of you.
  2. iRobot Roomba 560 Motherboard Replacement, Wheel Removal: adım 2, 1 resimden 1.
    • Remove the wheel using a spudger. You can probably also do this with your hand depending on how dirty the wheel is.
  3. iRobot Roomba 560 Motherboard Replacement, Wheel Removal: adım 3, 1 resimden 1.
    • Remove the wheel guiding inlay using the spudger or your hand.
  4. iRobot Roomba 560 Motherboard Replacement, Remove Main Brush: adım 4, 1 resimden 1.
    • Remove the main brush by unscrewing the single 5 mm screw on the yellow side sweeper using the Phillips #1 driver.
    • Once the screw is removed, lift out the brush and store the screw and brush.
  5. iRobot Roomba 560 Motherboard Replacement, Accessing the Battery: adım 5, 3 resimden 1. iRobot Roomba 560 Motherboard Replacement, Accessing the Battery: adım 5, 3 resimden 2. iRobot Roomba 560 Motherboard Replacement, Accessing the Battery: adım 5, 3 resimden 3.
    • Using the Phillips #1 driver, remove the four 10 mm screws that hold the back panel in place.
    • Once the four screws are removed, store the safely and lift up the back panel.
  6. iRobot Roomba 560 Motherboard Replacement, Remove the Vacuum-tray: adım 6, 2 resimden 1. iRobot Roomba 560 Motherboard Replacement, Remove the Vacuum-tray: adım 6, 2 resimden 2.
    • Remove the vacuum try to have an easier repair.
  7. iRobot Roomba 560 Motherboard Replacement, Removing the Battery: adım 7, 2 resimden 1. iRobot Roomba 560 Motherboard Replacement, Removing the Battery: adım 7, 2 resimden 2.
    • Locate the battery.
    • Lift up the yellow battery by pulling up the green tabs on its side.
    • Handle the battery with care.
  8. iRobot Roomba 560 Motherboard Replacement, Removing the wheels.: adım 8, 3 resimden 1. iRobot Roomba 560 Motherboard Replacement, Removing the wheels.: adım 8, 3 resimden 2. iRobot Roomba 560 Motherboard Replacement, Removing the wheels.: adım 8, 3 resimden 3.
    • Using the Phillips #1 driver, remove the three screws that hold back the wheel unit on each side. This is not required but will make the repair easier.
    • Lift out the wheel units and store safely.
    • Repeat on the other side.
  9. iRobot Roomba 560 Motherboard Replacement, Prepare for the mainboard extraction: adım 9, 2 resimden 1. iRobot Roomba 560 Motherboard Replacement, Prepare for the mainboard extraction: adım 9, 2 resimden 2.
    • Check that the unit now looks like this and all the parts are removed.
    • Flip the unit around.
  10. iRobot Roomba 560 Motherboard Replacement, Unhook front panel: adım 10, 1 resimden 1.
    • Use your hands to unhook the snaps between the silver panel from the black panel located where the vacuum bin was.
  11. iRobot Roomba 560 Motherboard Replacement, Remove top panel: adım 11, 3 resimden 1. iRobot Roomba 560 Motherboard Replacement, Remove top panel: adım 11, 3 resimden 2. iRobot Roomba 560 Motherboard Replacement, Remove top panel: adım 11, 3 resimden 3.
    • Using the ifixit spudgers pry under the main silver panel.
  12. iRobot Roomba 560 Motherboard Replacement, Panel removal: adım 12, 1 resimden 1.
    • Lift off the panel.
  13. iRobot Roomba 560 Motherboard Replacement, Remove front bumper: adım 13, 1 resimden 1.
    • Turn the unit around again and locate the 10 screws on the front bumper.
    • Using the Phillips #1 driver, remove the ten 10 mm screws on the bumper that run along the outer edge of the Roomba.
  14. iRobot Roomba 560 Motherboard Replacement, Lift off bumper: adım 14, 3 resimden 1. iRobot Roomba 560 Motherboard Replacement, Lift off bumper: adım 14, 3 resimden 2. iRobot Roomba 560 Motherboard Replacement, Lift off bumper: adım 14, 3 resimden 3.
    • Lift the thin top cover that holds the bumper in place.
    • Be very vigilant with the attached sensor. Otherwise you risk ripping off the cable and damaging the entire sensor.
  15. iRobot Roomba 560 Motherboard Replacement, Unscrew sensor: adım 15, 2 resimden 1. iRobot Roomba 560 Motherboard Replacement, Unscrew sensor: adım 15, 2 resimden 2.
    • Lift the bumper upwards for easier access.
    • Unscrew the two 5 mm screws that connect the red and white wires to the device using the Phillips #1 driver.
    • Lift the circular black panel off the sensor housing.
  16. iRobot Roomba 560 Motherboard Replacement, Turn: adım 16, 1 resimden 1.
    • Turn the unit back around.
  17. iRobot Roomba 560 Motherboard Replacement, Remove top screws: adım 17, 1 resimden 1.
    • Using the Phillips #1 driver, unscrew the following 13 screws that hold the black panel in place:
    • Two 5 mm on the bottom ends of the semicircle handle.
    • Ten 7.5 mm scattered on the Roomba.
    • One 5 mm at the bottom of control board.
  18. iRobot Roomba 560 Motherboard Replacement, Lift panel off: adım 18, 1 resimden 1.
    • Lift the black panel off the device.
  19. iRobot Roomba 560 Motherboard Replacement, Mainboard access: adım 19, 3 resimden 1. iRobot Roomba 560 Motherboard Replacement, Mainboard access: adım 19, 3 resimden 2. iRobot Roomba 560 Motherboard Replacement, Mainboard access: adım 19, 3 resimden 3.
    • Remove the outer silver circle, black plastic cover, and black film from the central control board in that order.
  20. iRobot Roomba 560 Motherboard Replacement, Control board removal: adım 20, 1 resimden 1.
    • Using the Phillips #1 driver, unscrew the four 10 mm screws that surround the clean button.
  21. iRobot Roomba 560 Motherboard Replacement, Remove panel: adım 21, 1 resimden 1.
  22. iRobot Roomba 560 Motherboard Replacement, Remove the protective sheet: adım 22, 2 resimden 1. iRobot Roomba 560 Motherboard Replacement, Remove the protective sheet: adım 22, 2 resimden 2.
    • Lift off the plastic sheet.
  23. iRobot Roomba 560 Motherboard Replacement, Remove the connectors: adım 23, 3 resimden 1. iRobot Roomba 560 Motherboard Replacement, Remove the connectors: adım 23, 3 resimden 2. iRobot Roomba 560 Motherboard Replacement, Remove the connectors: adım 23, 3 resimden 3.
    • Remove all the top connectors to the mainboard.
    • You can use ifixit's reverse pliers but you can also use your hands.
  24. iRobot Roomba 560 Motherboard Replacement, Remove mainboard screws: adım 24, 1 resimden 1.
    • Using the Phillips #1 driver, unscrew the five screws on the mainboard.
    • Do not rip out mainboard now!
  25. iRobot Roomba 560 Motherboard Replacement, Lift off mainboard carefully: adım 25, 3 resimden 1. iRobot Roomba 560 Motherboard Replacement, Lift off mainboard carefully: adım 25, 3 resimden 2. iRobot Roomba 560 Motherboard Replacement, Lift off mainboard carefully: adım 25, 3 resimden 3.
    • Carefully lift off the mainboard, moving it towards you.
    • Be very careful with the connected connectors.
  26. iRobot Roomba 560 Motherboard Replacement, Remove connectors: adım 26, 1 resimden 1.
    • Very carefully disconnect the connections off the mainboard.
    • You can ifixit's reverse pliers.
  27. iRobot Roomba 560 Motherboard Replacement, Remove sensor and replace board: adım 27, 2 resimden 1. iRobot Roomba 560 Motherboard Replacement, Remove sensor and replace board: adım 27, 2 resimden 2.
    • The sensor might still be attached/is not attached to the main unit but mainboard. Just unplug it.
    • You can now replace the mainboard and complete the steps from the bottom up to finish the replacement.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Max Lembke
951 İtibar
3 adet Kılavuz yazıldı
1Rehber Yorum
Greetings. I have two Model 560 sweepers. Neither of them has ever had a software update. I've tried resetting them to see if it will get them to complete a cleaning cycle, but they either short cycle back to the charger base, or crap out prematurely. I've installed a generic 5000 mAh battery, so there should be adequate power to complete two rooms with less than 50% carpet. Is there anybody out there who has one of the "Osmo" software updaters? I like the Model 560, and I have updated the gear drives and dust collectors, so I'd prefer NOT to junk them. Please advise.
Ed Allen, a.k.a. nostrodamos@live.com
Pasco, WA
(509) 542-1004
Ed Allen - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 94
Her zaman: 4,554
