Ana içeriğe geç
iRobot Roomba 560 Side Sweeper Replacement
Neye ihtiyacın var
  1. iRobot Roomba 560 Side Sweeper Replacement, Side Sweeper: adım 1, 1 resimden 1.
    • Flip the Roomba upside down.
    • Unscrew the single 5 mm screw on the yellow side sweeper using the Phillips #2 driver.
  2. iRobot Roomba 560 Side Sweeper Replacement: adım 2, 1 resimden 1.
    • Lift the yellow side sweeper, removing it from the device.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Mairead Blaes
825 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-22, Maness Fall 2015 Cal Poly, Team 1-22, Maness Fall 2015 üyesi
CPSU-MANESS-F15S1G22
4 Üyeler
14 adet Kılavuz yazıldı
2Kılavuz Yorumları
I need to replace the part on the bottom where the side sweeper screws in. The threads are stripped, I’m guessing, and screw won’t stay in.
Candy Schnurr - Yanıt
put some hot glue or melt some plastic in the hole before screwing it. you should get the threads back when you unscrew it
Nicolas Sicard -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 25
Her zaman: 1,859
