Ana içeriğe geç
iRobot Roomba 595 Pet Series Battery Replacement
Neye ihtiyacın var
  1. iRobot Roomba 595 Pet Series Battery Replacement, Secondary Brush: adım 1, 1 resimden 1.
    • Flip the Roomba upside down. Using the Phillips #0 screwdriver, carefully remove the 5 mm screw holding the brush in place.
  2. iRobot Roomba 595 Pet Series Battery Replacement: adım 2, 1 resimden 1.
    • Gently pull the brush up and remove it from the device.
  3. iRobot Roomba 595 Pet Series Battery Replacement, Battery: adım 3, 1 resimden 1.
    • Unscrew the four 10mm screws on the underside of the Roomba using a Phillips #1 screwdriver.
  4. iRobot Roomba 595 Pet Series Battery Replacement: adım 4, 1 resimden 1.
    • Remove the bottom frame of the device.
  5. iRobot Roomba 595 Pet Series Battery Replacement: adım 5, 1 resimden 1.
    • Grab the green tape attached to the end of the battery and remove the battery from the device.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Ekip
USF Tampa, Team S10-G5, Thompson Fall 2017 USF Tampa, Team S10-G5, Thompson Fall 2017 üyesi
USFT-THOMPSON-F17S10G5
3 Üyeler
5 adet Kılavuz yazıldı
2 Yorum
Pls, can i charge the roomba directly, because the base is not working??
elie moussa - Yanıt
Yes I think so, mine can
Big builder - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 39
Her zaman: 5,075
