Ana içeriğe geç
iRobot Roomba 595 Pet Series Main Brush Replacement
Neye ihtiyacın var
  1. iRobot Roomba 595 Pet Series Main Brush Replacement, Secondary Brush: adım 1, 1 resimden 1.
    • Flip the Roomba upside down. Using the Phillips #0 screwdriver, carefully remove the 5 mm screw holding the brush in place.
  2. iRobot Roomba 595 Pet Series Main Brush Replacement: adım 2, 1 resimden 1.
    • Gently pull the brush up and remove it from the device.
  3. iRobot Roomba 595 Pet Series Main Brush Replacement, Main Brush: adım 3, 2 resimden 1. iRobot Roomba 595 Pet Series Main Brush Replacement, Main Brush: adım 3, 2 resimden 2.
    • Remove the four 10mm screws with a Phillips #1 screwdriver. Gently lift off the external covering for the Roomba's underside.
  4. iRobot Roomba 595 Pet Series Main Brush Replacement: adım 4, 3 resimden 1. iRobot Roomba 595 Pet Series Main Brush Replacement: adım 4, 3 resimden 2. iRobot Roomba 595 Pet Series Main Brush Replacement: adım 4, 3 resimden 3.
    • Press lightly on the yellow tabs and lift the cage cover containing the brush.
  5. iRobot Roomba 595 Pet Series Main Brush Replacement: adım 5, 2 resimden 1. iRobot Roomba 595 Pet Series Main Brush Replacement: adım 5, 2 resimden 2.
    • Lift the brush from the right side and slide it from its container within the Roomba.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Dale Shirley-Potopsingh
446 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S10-G5, Thompson Fall 2017 USF Tampa, Team S10-G5, Thompson Fall 2017 üyesi
USFT-THOMPSON-F17S10G5
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 607
