Ana içeriğe geç
iRobot Roomba 595 Pet Series Wheel Spring Replacement
Neye ihtiyacın var
  1. iRobot Roomba 595 Pet Series Wheel Spring Replacement, Secondary Brush: adım 1, 1 resimden 1.
    • Flip the Roomba upside down. Using the Phillips #0 screwdriver, carefully remove the 5 mm screw holding the brush in place.
  2. iRobot Roomba 595 Pet Series Wheel Spring Replacement: adım 2, 1 resimden 1.
    • Gently pull the brush up and remove it from the device.
  3. iRobot Roomba 595 Pet Series Wheel Spring Replacement, Wheel Spring: adım 3, 2 resimden 1. iRobot Roomba 595 Pet Series Wheel Spring Replacement, Wheel Spring: adım 3, 2 resimden 2.
    • Unscrew the four 10mm screws on the underside of the Roomba with a Phillips #1 screwdriver.
    • Remove the Roomba's external underside.
  4. iRobot Roomba 595 Pet Series Wheel Spring Replacement: adım 4, 1 resimden 1.
    • Remove the 15 mm screws with the Phillips #0 screwdriver bit.
  5. iRobot Roomba 595 Pet Series Wheel Spring Replacement: adım 5, 1 resimden 1.
    • Once the screws have been taken care of, the wheel component (with the spring inside) can be removed from the main assembly.
  6. iRobot Roomba 595 Pet Series Wheel Spring Replacement: adım 6, 3 resimden 1. iRobot Roomba 595 Pet Series Wheel Spring Replacement: adım 6, 3 resimden 2. iRobot Roomba 595 Pet Series Wheel Spring Replacement: adım 6, 3 resimden 3.
    • Remove the two 5mm screws in the component and gently twist the casing until the spring is exposed.
    • Carefully remove the spring from the component assembly as shown
Sonuç
Dale Shirley-Potopsingh
446 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S10-G5, Thompson Fall 2017 USF Tampa, Team S10-G5, Thompson Fall 2017 üyesi
USFT-THOMPSON-F17S10G5
3 Üyeler
5 adet Kılavuz yazıldı
4 Yorum
My spring has fallen out and you don’t show where the spring attatches
Rebecca Hubber - Yanıt
Where can I get a new spring, mine is missing on the left wheel
emls23 - Yanıt
The bracket for the front (white and black) wheel broke. Where can I get a new one?
Kathryn Roberts - Yanıt
Where can I get a new spring for right wheel? Do these questions ever get answered?
KMF - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 1,646
