Ana içeriğe geç
iRobot Roomba 630 Side Brush Motor Replacement
Neye ihtiyacın var
  1. iRobot Roomba 630 Side Brush Motor Replacement, Side Brush Motor: adım 1, 2 resimden 1. iRobot Roomba 630 Side Brush Motor Replacement, Side Brush Motor: adım 1, 2 resimden 2.
    • Flip the Roomba over so that the wheels are facing upwards.
    • Unscrew the 6 mm screw from the yellow side brush using a Phillips #2 screwdriver.
  2. iRobot Roomba 630 Side Brush Motor Replacement: adım 2, 2 resimden 1. iRobot Roomba 630 Side Brush Motor Replacement: adım 2, 2 resimden 2.
    • Remove the four 10.1 mm screws from the back cover using a Phillips #2 screwdriver.
    • Lift the back cover off to access the gear box.
  3. iRobot Roomba 630 Side Brush Motor Replacement: adım 3, 3 resimden 1. iRobot Roomba 630 Side Brush Motor Replacement: adım 3, 3 resimden 2. iRobot Roomba 630 Side Brush Motor Replacement: adım 3, 3 resimden 3.
    • Remove the three outer 15 mm screws that hold down the gearbox using a Phillips #2 screwdriver.
    • Remove the middle 15 mm screw to release the gearbox using a tri-point Y0 screwdriver.
    • Lift the blue side brush gear box out.
  4. iRobot Roomba 630 Side Brush Motor Replacement: adım 4, 2 resimden 1. iRobot Roomba 630 Side Brush Motor Replacement: adım 4, 2 resimden 2.
    • Pry the top of the gear box off.
    • Check for debris in the gear box and clean it out if needed.
  5. iRobot Roomba 630 Side Brush Motor Replacement: adım 5, 3 resimden 1. iRobot Roomba 630 Side Brush Motor Replacement: adım 5, 3 resimden 2. iRobot Roomba 630 Side Brush Motor Replacement: adım 5, 3 resimden 3.
    • Remove the screws holding the motor in place using a Phillips #2 screwdriver.
    • Pull the old motor out.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Jabari Baptiste
485 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S5-G3, Walkup Fall 2017 USF Tampa, Team S5-G3, Walkup Fall 2017 üyesi
USFT-WALKUP-F17S5G3
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 40
Her zaman: 1,994
