Ana içeriğe geç
iRobot Roomba 655 Pet Series Battery Replacement
Neye ihtiyacın var
  1. iRobot Roomba 655 Pet Series Battery Replacement, Removing the Side Brush: adım 1, 2 resimden 1. iRobot Roomba 655 Pet Series Battery Replacement, Removing the Side Brush: adım 1, 2 resimden 2.
    • Flip the device over onto its back.
    • Find the side brush, and unscrew the single screw that connects to brush motor by using the Phillips head #2 screwdriver.
    • This screw doesn't completely come out of the yellow side brush.
  2. iRobot Roomba 655 Pet Series Battery Replacement, Removing the Back Panel: adım 2, 2 resimden 1. iRobot Roomba 655 Pet Series Battery Replacement, Removing the Back Panel: adım 2, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the four screws on the back panel.
    • Once the screws are loose gently pry the back plate away from the body by using the spudger tool.
    • The screws don't completely come out of the panel, but it will still come apart once unscrewed.
  3. iRobot Roomba 655 Pet Series Battery Replacement, Removing the Battery: adım 3, 3 resimden 1. iRobot Roomba 655 Pet Series Battery Replacement, Removing the Battery: adım 3, 3 resimden 2. iRobot Roomba 655 Pet Series Battery Replacement, Removing the Battery: adım 3, 3 resimden 3.
    • Grab the two pieces of green tape with your thumb and index finger
    • Pull up on the battery in an upwards direction to remove it
  4. iRobot Roomba 655 Pet Series Battery Replacement, Battery Contact Points: adım 4, 2 resimden 1. iRobot Roomba 655 Pet Series Battery Replacement, Battery Contact Points: adım 4, 2 resimden 2.
    • These are the contact points on the Roomba for the battery
    • These are the contact points on the battery
    • If these contact points are dirty, they can be cleaned with a moist microfiber cloth (distilled water recommended)
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Matt Davis
1.642 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-20, Maness Winter 2015 Cal Poly, Team 21-20, Maness Winter 2015 üyesi
CPSU-MANESS-W15S21G20
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 42
Her zaman: 12,831
