Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
iRobot Roomba 655 Pet Series Battery Replacement
Neye ihtiyacın var
  1. iRobot Roomba 655 Pet Series Battery Replacement, Removing the Side Brush: adım 1, 2 resimden 1. iRobot Roomba 655 Pet Series Battery Replacement, Removing the Side Brush: adım 1, 2 resimden 2.
    • Flip the device over onto its back.
    • Find the side brush, and unscrew the single screw that connects to brush motor by using the Phillips head #2 screwdriver.
    • This screw doesn't completely come out of the yellow side brush.
  2. iRobot Roomba 655 Pet Series Battery Replacement, Removing the Back Panel: adım 2, 2 resimden 1. iRobot Roomba 655 Pet Series Battery Replacement, Removing the Back Panel: adım 2, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the four screws on the back panel.
    • Once the screws are loose gently pry the back plate away from the body by using the spudger tool.
    • The screws don't completely come out of the panel, but it will still come apart once unscrewed.
  3. iRobot Roomba 655 Pet Series Battery Replacement, Removing the Battery: adım 3, 3 resimden 1. iRobot Roomba 655 Pet Series Battery Replacement, Removing the Battery: adım 3, 3 resimden 2. iRobot Roomba 655 Pet Series Battery Replacement, Removing the Battery: adım 3, 3 resimden 3.
    • Grab the two pieces of green tape with your thumb and index finger
    • Pull up on the battery in an upwards direction to remove it
  4. iRobot Roomba 655 Pet Series Battery Replacement, Battery Contact Points: adım 4, 2 resimden 1. iRobot Roomba 655 Pet Series Battery Replacement, Battery Contact Points: adım 4, 2 resimden 2.
    • These are the contact points on the Roomba for the battery
    • These are the contact points on the battery
    • If these contact points are dirty, they can be cleaned with a moist microfiber cloth (distilled water recommended)
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Matt Davis
1.624 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-20, Maness Winter 2015 Cal Poly, Team 21-20, Maness Winter 2015 üyesi
CPSU-MANESS-W15S21G20
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 18
Son 30 gün: 66
Her zaman: 12,712
