Giriş
Sometimes you just want a some new wheels right?! This guide will show you how to replace the wheels that drive your Roomba to become the cleaning machine that it is.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Flip the device over onto its back.
Find the side brush, and unscrew the single screw that connects to brush motor by using the Phillips head #2 screwdriver.
Using a Phillips #1 screwdriver, remove the four screws on the back panel.
Once the screws are loose gently pry the back plate away from the body by using the spudger tool.
Grab the two pieces of green tape with your thumb and index finger
Pull up on the battery in an upwards direction to remove it
These are the contact points on the Roomba for the battery
These are the contact points on the battery
Remove the three screws with your Phillips head #1, holding the drive wheels in place
Bir başkası bu kılavuzu tamamladı.
