Ana içeriğe geç
iRobot Roomba 655 Pet Series Internal Faceplate Removal
Neye ihtiyacın var
  1. iRobot Roomba 655 Pet Series Internal Faceplate Removal, Front Face Plate: adım 1, 2 resimden 1. iRobot Roomba 655 Pet Series Internal Faceplate Removal, Front Face Plate: adım 1, 2 resimden 2.
    • Remove the dust bin by pushing on the button for the dust bin removal
    • Pull the dust bin out
  2. iRobot Roomba 655 Pet Series Internal Faceplate Removal: adım 2, 2 resimden 1. iRobot Roomba 655 Pet Series Internal Faceplate Removal: adım 2, 2 resimden 2.
    • Pull up on the silver handle to release the top protectant plastic
    • Remove the top plastic carefully
  3. iRobot Roomba 655 Pet Series Internal Faceplate Removal, Front Bumper: adım 3, 2 resimden 1. iRobot Roomba 655 Pet Series Internal Faceplate Removal, Front Bumper: adım 3, 2 resimden 2.
    • Remove the ten 11mm screws that hold the front bumper to the plastic bumper protector with your Phillips #1 screwdriver.
    • Pull the plastic bumper protector up and off of the bumper.
  4. iRobot Roomba 655 Pet Series Internal Faceplate Removal: adım 4, 3 resimden 1. iRobot Roomba 655 Pet Series Internal Faceplate Removal: adım 4, 3 resimden 2. iRobot Roomba 655 Pet Series Internal Faceplate Removal: adım 4, 3 resimden 3.
    • Flip the Roomba back over, so you are viewing the top.
    • Pull up on the front bumper to remove it.
    • Be careful not to pull too hard because there is wiring attached to the bumper.
    • Remove the two 7mm screws with your Phillips #1 screwdriver, holding the wire sensors in place to the front bumper.
  5. iRobot Roomba 655 Pet Series Internal Faceplate Removal, Internal Faceplate: adım 5, 3 resimden 1. iRobot Roomba 655 Pet Series Internal Faceplate Removal, Internal Faceplate: adım 5, 3 resimden 2. iRobot Roomba 655 Pet Series Internal Faceplate Removal, Internal Faceplate: adım 5, 3 resimden 3.
    • The outside six - 10mm screws and the inside set of four - 10mm screws are the same here, use your Phillips head #2 to remove them
    • Use your Phillips head #0 to remove the one - 7mm bottom center screw
    • Use your Phillips head #2 to remove the two - 8mm screws by the handle
    • Push down the two release points to pull the plastic piece up
    • Pull the plastic piece up
Sonuç
Rhett
1.350 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-20, Maness Winter 2015 Cal Poly, Team 21-20, Maness Winter 2015 üyesi
CPSU-MANESS-W15S21G20
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 30
Her zaman: 813
