Ana içeriğe geç
iRobot Roomba 655 Pet Series Side Brush Motor Replacement
Neye ihtiyacın var
  1. iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Side Brush Motor: adım 1, 3 resimden 1. iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Side Brush Motor: adım 1, 3 resimden 2. iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Side Brush Motor: adım 1, 3 resimden 3.
    • First start by removing the two - 6mm screws with your Phillips head #1, that unlock the motor from your Roomba
    • Pull the brush motor out
  2. iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Gear Box Cover: adım 2, 3 resimden 1. iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Gear Box Cover: adım 2, 3 resimden 2. iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Gear Box Cover: adım 2, 3 resimden 3.
    • Next, with the same head remove the screw holding the plastic housing together
    • Carefully pry the gear box open by placing a flat head screwdriver in the slot
    • This might be difficult and require some shifting of the screwdriver
  3. iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Motor Removal: adım 3, 3 resimden 1. iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Motor Removal: adım 3, 3 resimden 2. iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Motor Removal: adım 3, 3 resimden 3.
    • Removing these two screws will allow you to access the motor (use the same head as before)
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Matt Davis
1.642 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-20, Maness Winter 2015 Cal Poly, Team 21-20, Maness Winter 2015 üyesi
CPSU-MANESS-W15S21G20
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 1,664
