Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
You will be removing the yellow side brush and the back panel of your Roomba in order to gain access to other components of your device.
Neye ihtiyacın var
Flip the device over onto its back
Find the side brush, and unscrew the single screw that connects to brush motor by using the Phillips head #2 screwdriver
Locate and Remove the four screws on the back panel by using Phillips #1
Once the screws are loose gently pry the back plate away from the body by using the spudger tool.
