Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
You will be removing the yellow side brush and the back panel of your Roomba in order to gain access to other components of your device.
Parçalar
Hiçbir parça belirtilmedi.
  1. Flip the device over onto its back. Find the side brush, and unscrew the single screw that connects to brush motor  by using the Phillips head #2 screwdriver.
    • Flip the device over onto its back.
    • Find the side brush, and unscrew the single screw that connects to brush motor by using the Phillips head #2 screwdriver.
    • This screw doesn't completely come out of the yellow side brush.
  2. Using a Phillips #1 screwdriver, remove the four screws on the back panel. Once the screws are loose gently pry the back plate away from the body by using the spudger tool.
    • Using a Phillips #1 screwdriver, remove the four screws on the back panel.
    • Once the screws are loose gently pry the back plate away from the body by using the spudger tool.
    • The screws don't completely come out of the panel, but it will still come apart once unscrewed.
Sonuç
Matt Davis
1.457 İtibar
7 adet Kılavuz yazıldı
Takım
Cal Poly, Team 21-20, Maness Winter 2015 Cal Poly, Team 21-20, Maness Winter 2015 üyesi
CPSU-MANESS-W15S21G20
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 1,326
