Ana içeriğe geç
iRobot Roomba 770 Brush Replacement
  1. iRobot Roomba 770 Brush Replacement, Brush: adım 1, 1 resimden 1.
    • Orient the roomba so it is upside down and the dust tray is closest to you.
  2. iRobot Roomba 770 Brush Replacement: adım 2, 2 resimden 1. iRobot Roomba 770 Brush Replacement: adım 2, 2 resimden 2.
    • Locate the two yellow tabs on the screen that covers the brushes.
    • Push inwards on the yellow tabs while simultaneously pulling upwards on the attached grey cage.
  3. iRobot Roomba 770 Brush Replacement: adım 3, 3 resimden 1. iRobot Roomba 770 Brush Replacement: adım 3, 3 resimden 2. iRobot Roomba 770 Brush Replacement: adım 3, 3 resimden 3.
    • Grab the right side of the larger brush that is located near the yellow cap. Pull upwards and to the right to remove the brush.
    • Repeat the same steps with the smaller brush.
  4. iRobot Roomba 770 Brush Replacement: adım 4, 2 resimden 1. iRobot Roomba 770 Brush Replacement: adım 4, 2 resimden 2.
    • Orient the brush so the yellow tab is on the right hand side.
    • Pull the yellow tab to the right to remove.
    • Remove any debris, paying attention to the ends as well as the brush itself.
    • Replace any damaged brushes.
Sonuç
Andrew Horvath
444 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-3, Livingston Fall 2016 Cal Poly, Team 15-3, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S15G3
3 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
My roomba starts and moves a foot or so and then stops. I have cleaned it entirely, the battery is fine and the wheels are clean. Anyone have a suggestion
Mary Ann Dyer - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 20
Her zaman: 2,326
