Ana içeriğe geç
iRobot Roomba 770 Main Wheels Replacement
Neye ihtiyacın var
  1. iRobot Roomba 770 Main Wheels Replacement, Battery: adım 1, 2 resimden 1. iRobot Roomba 770 Main Wheels Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the Roomba over so that the wheels are facing up and the dust tray is closest to you.
    • Using the J1 Phillips screwdriver, locate and unscrew the two 11mm phillips screws above the brushes on the battery panel.
    • Remove the plastic plate from the battery box.
  2. iRobot Roomba 770 Main Wheels Replacement: adım 2, 2 resimden 1. iRobot Roomba 770 Main Wheels Replacement: adım 2, 2 resimden 2.
    • Locate the 2 green tabs on the left and right of the big yellow battery.
    • Grab the tabs with your hands and lift straight upward.
  3. iRobot Roomba 770 Main Wheels Replacement, Side Brush Motor: adım 3, 1 resimden 1.
    • Using the J1 Philips Screwdriver, remove the 15.5 mm screw located in the center of the side brush.
    • Remove the brush by pulling upwards.
    • Do not lean directly over the brush when attempting to remove. Removing the brush requires a firm pull and may release suddenly.
  4. iRobot Roomba 770 Main Wheels Replacement: adım 4, 2 resimden 1. iRobot Roomba 770 Main Wheels Replacement: adım 4, 2 resimden 2.
    • Using the J1 Philips Screwdriver, remove the two 15.5 mm screws located on the bottom of the plate covering the bottom of the roomba.
    • Lift upwards to remove the bottom plate.
  5. iRobot Roomba 770 Main Wheels Replacement: adım 5, 2 resimden 1. iRobot Roomba 770 Main Wheels Replacement: adım 5, 2 resimden 2.
    • Using the J1 Philips Screwdriver, remove the two gold 15.5 mm screws located on the blue plastic module the side brush had previously been attached too.
    • Lift the blue module upwards. The module contains the motor for the side brush.
  6. iRobot Roomba 770 Main Wheels Replacement, Main Wheels: adım 6, 2 resimden 1. iRobot Roomba 770 Main Wheels Replacement, Main Wheels: adım 6, 2 resimden 2.
    • Locate the three 15.5 mm screws surrounding each wheel. Use a J1 Philips screw driver to remove these.
    • The screw towards the center for each wheel may be hard to locate and may seem inaccessible. The head of your screw is long enough to reach it.
    • Use your J1 Philips screwdriver to remove these screws.
  7. iRobot Roomba 770 Main Wheels Replacement: adım 7, 2 resimden 1. iRobot Roomba 770 Main Wheels Replacement: adım 7, 2 resimden 2.
    • Pull up on the wheels to remove them from the device.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Angelique Bonilla
251 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 15-3, Livingston Fall 2016 Cal Poly, Team 15-3, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S15G3
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 29
Her zaman: 3,059
