Ana içeriğe geç
iRobot Roomba 860 Battery Replacement
Neye ihtiyacın var
  1. iRobot Roomba 860 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Start by powering down the device to remove the battery from the iRobot Roomba 860.
  2. iRobot Roomba 860 Battery Replacement: adım 2, 2 resimden 1. iRobot Roomba 860 Battery Replacement: adım 2, 2 resimden 2.
    • Flip the Roomba over so that the underside is facing up.
    • Locate the battery panel and the 2 - 7 mm Phillips #2 Point Screws.
    • Using a Phillips #2 Point Screwdriver, remove the screws and use your fingers to pull the cover away from the device.
  3. iRobot Roomba 860 Battery Replacement: adım 3, 2 resimden 1. iRobot Roomba 860 Battery Replacement: adım 3, 2 resimden 2.
    • Locate the two fabric tabs on the side of the battery.
    • Pull up on the tabs to easily remove the battery.
Sonuç
Ryan Murphy
446 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S13-G5, Cagle Spring 2017 USF Tampa, Team S13-G5, Cagle Spring 2017 üyesi
USFT-CAGLE-S17S13G5
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 24
Her zaman: 1,131
