Giriş
Is your Roomba not able to sense surrounding obstacles, preventing it from avoiding such barriers? If so, here is the guide to fix the problem with a simple change of the bumper sensor. All you need are the standard #0 and #1 Phillips Screwdriver heads in order to remove the two types of screws involved with this replacement.
Neye ihtiyacın var
Flip the iRoomba over so that the underside is facing up.
Using the Phillips #0 screwdriver, remove the 4.0 mm screw in the center of the yellow side brush.
Remove the yellow side brush.
13 farklı kişi bu kılavuzu tamamladı.
3Kılavuz Yorumları
man kommt nicht an den Stecker. Die Anleitung bringt überhaupt nichts.
