Ana içeriğe geç
iRobot Roomba 870 Bumper Sensor Replacement
Neye ihtiyacın var
  1. iRobot Roomba 870  Bumper Sensor Replacement, Bumper Sensor: adım 1, 2 resimden 1. iRobot Roomba 870  Bumper Sensor Replacement, Bumper Sensor: adım 1, 2 resimden 2.
    • Flip the iRoomba over so that the underside is facing up.
    • Using the Phillips #0 screwdriver, remove the 4.0 mm screw in the center of the yellow side brush.
    • Remove the yellow side brush.
  2. iRobot Roomba 870  Bumper Sensor Replacement: adım 2, 3 resimden 1. iRobot Roomba 870  Bumper Sensor Replacement: adım 2, 3 resimden 2. iRobot Roomba 870  Bumper Sensor Replacement: adım 2, 3 resimden 3.
    • Remove the two 3.5 mm Phillips screws that hold the battery cover onto the Roomba with a Phillips #0 screwdriver.
    • Remove the battery cover.
  3. iRobot Roomba 870  Bumper Sensor Replacement: adım 3, 3 resimden 1. iRobot Roomba 870  Bumper Sensor Replacement: adım 3, 3 resimden 2. iRobot Roomba 870  Bumper Sensor Replacement: adım 3, 3 resimden 3.
    • Remove the two remaining 3.5 mm Phillips #0 screws that attach the base-plate to the bottom of the Roomba.
    • Remove the entire base-plate from the bottom of the Roomba.
  4. iRobot Roomba 870  Bumper Sensor Replacement: adım 4, 3 resimden 1. iRobot Roomba 870  Bumper Sensor Replacement: adım 4, 3 resimden 2. iRobot Roomba 870  Bumper Sensor Replacement: adım 4, 3 resimden 3.
    • Remove the ten 3 mm screws that attach the bumper guard to the bumper with a Phillips #1 screwdriver.
    • Remove the bumper guard.
  5. iRobot Roomba 870  Bumper Sensor Replacement: adım 5, 2 resimden 1. iRobot Roomba 870  Bumper Sensor Replacement: adım 5, 2 resimden 2.
    • Be careful when removing the bumper from the Roomba to prevent damage to the sensor wires. Remove slowly!
    • Lift up the Roomba so that its bumper is not resting on anything, and slowly separate the bumper from the device.
  6. iRobot Roomba 870  Bumper Sensor Replacement: adım 6, 3 resimden 1. iRobot Roomba 870  Bumper Sensor Replacement: adım 6, 3 resimden 2. iRobot Roomba 870  Bumper Sensor Replacement: adım 6, 3 resimden 3.
    • Remove the two 3 mm screws that attach the sensor connector to the bumper/sensor with a #1 Phillips Screwdriver.
    • Carefully detach the sensor connector from the bumper and the sensor.
  7. iRobot Roomba 870  Bumper Sensor Replacement: adım 7, 2 resimden 1. iRobot Roomba 870  Bumper Sensor Replacement: adım 7, 2 resimden 2.
    • The sensor is now loose on the bumper. Be careful not to rapidly move the bumper for fear of dislodging the sensor and breaking it.
    • Flip the bumper over, ensuring the sensor remains inside the sensor compartment.
    • Gently remove the bumper from the black infrared sensor.
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
Jacob Lindberg
449 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S14-G3, Banghart Spring 2017 Cal Poly, Team S14-G3, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S14G3
4 Üyeler
10 adet Kılavuz yazıldı
3 Yorum
Can not get to the plug-in area on the board to replace sensor this way. DOES NOT work this way.
jkeysgate - Yanıt
man kommt nicht an den Stecker. Die Anleitung bringt überhaupt nichts.
Reinhard Totzauer - Yanıt
Incomplete. This NEEDs to explain how to access the plug on the board.
Ed T. - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 24
Son 30 gün: 137
Her zaman: 7,657
