Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Flip the iRoomba over so that the underside is facing up.
Using the Phillips #0 screwdriver, remove the 4.0 mm screw in the center of the yellow side brush.
Remove the yellow side brush.
Remove the two 3.5 mm Phillips screws that hold the battery cover onto the Roomba with a Phillips #0 screwdriver.
Remove the battery cover.
Remove the two remaining 3.5 mm Phillips #0 screws that attach the base-plate to the bottom of the Roomba.
Remove the entire base-plate from the bottom of the Roomba.
Remove the ten 3 mm screws that attach the bumper guard to the bumper with a Phillips #1 screwdriver.
Remove the bumper guard.
Lift up the Roomba so that its bumper is not resting on anything, and slowly separate the bumper from the device.
Remove the two 3 mm screws that attach the sensor connector to the bumper/sensor with a #1 Phillips Screwdriver.
Carefully detach the sensor connector from the bumper and the sensor.
Flip the bumper over, ensuring the sensor remains inside the sensor compartment.
Gently remove the bumper from the black infrared sensor.
13 farklı kişi bu kılavuzu tamamladı.
3 Yorum
man kommt nicht an den Stecker. Die Anleitung bringt überhaupt nichts.
